man pages section 3: Extended Library Functions, Volume 1
Exit Print View
Updated: July 2014
di_prom_prop_data(3DEVINFO)
Name
di_prom_prop_data, di_prom_prop_next, di_prom_prop_name - access PROM device information
Synopsis
cc [ flag... ] file... –ldevinfo [ library... ]
#include <libdevinfo.h>
di_prom_prop_t di_prom_prop_next(di_prom_handle_t ph, di_node_t node,
     di_prom_prop_t prom_prop);
char *di_prom_prop_name(di_prom_prop_t prom_prop);
int di_prom_prop_data(di_prom_prop_t prom_prop, uchar_t **prop_data);
Parameters
node
Handle to a device node in the snapshot of kernel device tree.
ph
PROM handle
prom_prop
Handle to a PROM property.
prop_data
Address of a pointer.
Description
The di_prom_prop_next() function obtains a handle to the next property on the PROM property list associated with node. If prom_prop is DI_PROM_PROP_NIL, the first property associated with node is returned.
The di_prom_prop_name() function returns the name of the prom_prop property.
The di_prom_prop_data() function returns the value of the prom_prop property. The return value is a non-negative integer specifying the size in number of bytes in prop_data.
All memory allocated by these functions is managed by the library and must not be freed by the caller.
Return Values
The di_prom_prop_data() function returns the number of bytes in prop_data and prop_data is updated to point to a byte array containing the property value. If 0 is returned, the property is a boolean property and the existence of this property indicates the value is true.
The di_prom_prop_name() function returns a pointer to a string that contains the name of prom_prop.
The di_prom_prop_next() function returns a handle to the next PROM property. DI_PROM_PROP_NIL is returned if no additional properties exist.
Errors
See openprom(7D) for a description of possible errors.
Attributes
ATTRIBUTE TYPE
ATTRIBUTE VALUE
Interface Stability
Committed
MT-Level
Safe
See also
attributes(5), openprom(7D)
Writing Device Drivers for Oracle Solaris 11.2
