man pages section 3: Extended Library Functions, Volume 1
Exit Print View
Updated: July 2014
fstyp_mod_ident(3FSTYP)
Name
fstyp_mod_init, fstyp_mod_fini, fstyp_mod_ident, fstyp_mod_get_attr, fstyp_mod_dump - libfstyp module interface
Synopsis
cc [ flag… ] file–lfstyp –lnvpair [ library… ]
#include <libnvpair.h>
#include <libfstyp.h>
int fstyp_mod_init(int fd, off64_t **offset, fstyp_mod_handle_t *handle);
void fstyp_mod_fini(fstyp_mod_handle_t handle);
int fstyp_mod_ident(fstyp_mod_handle_t handle);
int fstyp_mod_get_attr(fstyp_mod_handle_t handle, nvlist_t **attr);
int fstyp_mod_dump(fstyp_mod_handle_t handle, FILE *fout, FILE *ferr);
Parameters
fd
Open file descriptor of a block or a raw device that contains the file system to be identified.
offset
Offset from the beginning of the device where the file system is located.
handle
Opaque handle that the module returns in fstyp_mod_init() and is used with other module functions.
fout
Output stream.
ferr
Error stream.
Description
A libfstyp module implements heuristics required to identify a file system type. The modules are shared objects loaded by libfstyp. The libfstyp modules are located in /usr/lib/fs subdirectories. A subdirectory name defines the name of the file system.
Each module exports the fstyp_mod_init(), fstyp_mod_fini(), fstyp_mod_ident(), and fstyp_mod_get_attr() functions. All of these functions map directly to the respective libfstyp interfaces.
The fstyp_mod_dump() function is optional. It can be used to output unformatted information about the file system. This function is used by the fstyp(1M) command when the –v option is specified. The fstyp_mod_dump() function is not recommended and should be used only in legacy modules.
Files
/usr/lib/fs/
Default module directory.
/usr/lib/fs/fstype/fstyp.so.1
Default path to a libfstyp module for an fstype file system.
Attributes
ATTRIBUTE TYPE
ATTRIBUTE VALUE
Interface Stability
Committed
MT-Level
MT-Safe
See Also
fstyp(1M), fstyp_strerror(3FSTYP), libfstyp(3LIB), attributes(5)
