man pages section 3: Extended Library Functions, Volume 1
Exit Print View
Updated: July 2014
di_prop_lookup_ints(3DEVINFO)
Name
di_prop_lookup_bytes, di_prop_lookup_ints, di_prop_lookup_int64, di_prop_lookup_strings, di_prop_exists - search for a property
Synopsis
cc [ flag... ] file... –ldevinfo [ library... ]
#include <libdevinfo.h>
int di_prop_lookup_bytes(dev_t dev, di_node_t node,
     const char *prop_name, uchar_t **prop_data);
int di_prop_lookup_ints(dev_t dev, di_node_t node,
     const char *prop_name, int **prop_data);
int di_prop_lookup_int64(dev_t dev, di_node_t node,
     const char *prop_name, int64_t **prop_data);
int di_prop_lookup_strings(dev_t dev, di_node_t node,
     const char *prop_name, char **prop_data);
int di_prop_exists(dev_t dev, di_node_t node,
     const char *prop_name);
Parameters
dev
dev_t of minor node with which the property is associated. DDI_DEV_T_ANY is a wild card that matches all dev_t's, including DDI_DEV_T_NONE.
node
Handle to the device node with which the property is associated.
prop_data
For di_prop_lookup_bytes(), the address to a pointer to an array of unsigned characters containing the property data.
For di_prop_lookup_ints(), the address to a pointer to an array of integers containing the property data.
For di_prop_lookup_int64(), the address to a pointer to an array of 64–bit integers containing the property data.
For di_prop_lookup_strings(), the address to a pointer to a buffer containing a concatenation of null-terminated strings containing the property data.
prop_name
Name of the property for which to search.
Description
These functions return the value of a known property name type and dev_t value. All memory allocated by these functions is managed by the library and must not be freed by the caller.
Return Values
If the property is found, the number of entries in prop_data is returned. If the property is a boolean type, 0 is returned and the existence of this property indicates the value is true. Otherwise, -1 is returned and errno is set to indicate the error.
The ddi_prop_exists() returns 1 if a property, including a boolean property, exists, and 0 otherwise.
Errors
These functions will fail if:
EINVAL
Invalid argument.
ENOTSUP
The snapshot contains no property information.
ENXIO
The property does not exist; try di_prom_prop_lookup_*().
Attributes
ATTRIBUTE TYPE
ATTRIBUTE VALUE
Interface Stability
Committed
MT-Level
Safe
See Also
di_init(3DEVINFO), di_prom_prop_lookup_bytes(3DEVINFO), libdevinfo(3LIB), attributes(5)
Writing Device Drivers for Oracle Solaris 11.2
