man pages section 3: Extended Library Functions, Volume 1
Exit Print View
Updated: July 2014
dat_ep_reset(3DAT)
Name
dat_ep_reset - transition the local Endpoint from a Disconnected to an Unconnected state
Synopsis
cc [ flag… ] file–ldat [ library… ]
#include <dat/udat.h>
DAT_RETURN
    dat_ep_reset (
    IN    DAT_EP_HANDLE    ep_handle
Parameters
ep_handle
Handle for an instance of Endpoint.
Description
The dat_ep_reset() function transitions the local Endpoint from a Disconnected to an Unconnected state.
The operation might cause the loss of any completions of previously posted DTOs and RMRs that were not dequeued yet.
The dat_ep_reset() function is valid for both Disconnected and Unconnected states. For Unconnected state, the operation is no-op because the Endpoint is already in an Unconnected state. For an Unconnected state, the preposted Recvs are not affected by the call.
Return Values
DAT_SUCCESS
The operation was successful.
DAT_INVALID_HANDLE
ep_handle is invalid.
DAT_INVALID_STATE
Parameter in an invalid state. Endpoint is not in the valid state for reset.
Usage
If the Consumer wants to ensure that all Completions are dequeued, the Consumer can post DTO or RMR operations as a "marker" that are flushed to recv_evd_handle or request_evd_handle. Now, when the Consumer dequeues the completion of the "marker" from the EVD, it is guaranteed that all previously posted DTO and RMR completions for the Endpoint were dequeued for that EVD. Now, it is safe to reset the Endpoint without losing any completions.
Attributes
ATTRIBUTE TYPE
ATTRIBUTE VALUE
Interface Stability
Committed
MT-Level
Unsafe
Standard
uDAPL, 1.1, 1.2
See Also
libdat(3LIB), attributes(5)
