using_threads - In a parallel environment, if called from a serial region of the master thread it returns the number of threads available for execution (determined by function OMP_GET_NUM_THREADS). Else, if it is called from a thread in the team executing the parallel region it returns a 1. USING_THREADS subroutine
INTEGER FUNCTION USING_THREADS() INTEGER*8 FUNCTION USING_THREADS_64() F95 INTERFACE INTEGER FUNCTION USING_THREADS() INTEGER(8) FUNCTION USING_THREADS_64() C INTERFACE #include <sunperf.h> int using_threads(); long using_threads_64();
Oracle Solaris Studio Performance Library using_threads(3P) NAME using_threads - In a parallel environment, if called from a serial region of the master thread it returns the number of threads available for execution (determined by function OMP_GET_NUM_THREADS). Else, if it is called from a thread in the team executing the parallel region it returns a 1. USING_THREADS subroutine SYNOPSIS INTEGER FUNCTION USING_THREADS() INTEGER*8 FUNCTION USING_THREADS_64() F95 INTERFACE INTEGER FUNCTION USING_THREADS() INTEGER(8) FUNCTION USING_THREADS_64() C INTERFACE #include <sunperf.h> int using_threads(); long using_threads_64(); PURPOSE In a parallel environment, if called from a serial region of the master thread USING_THREADS returns the number of threads available for execu- tion. This number is determined by function call OMP_GET_NUM_THREADS (See the specifications for the OpenMP Fortran Application Program Interface at http://www.openmp.org for more details on OMP_GET_NUM_THREADS). Else, if it is called from a thread in the team executing the parallel region, it returns a 1. A user routine can call using_threads to determine if it is already in a parallel region. If this is the case, a 1 is returned and the routine can choose the serial path instead of going parallel, thus avoiding nested parallellism. 7 Nov 2015 using_threads(3P)
