This is a hot-service procedure that can be performed by a customer while the server is running.
Caution - Hazardous voltages are present. To reduce the risk of electric shock and danger to personal health, follow the instructions. |
Caution - If a power supply fails and you do not have a replacement available, to ensure proper airflow, leave the failed power supply installed in the server until you replace it with a new power supply. |
For instructions for disconnecting the CMA left-side connectors, see Remove the Cable Management Arm.
Caution - When disconnecting the CMA left-side connectors, use your arm to support the CMA so that it does not hang down under its own weight and stress the right-side connectors; otherwise, the CMA might be damaged. You must continue to support the CMA until you have reconnected both of the left-side connectors. |
Caution - Replace the power supply within 5 minutes to ensure proper system cooling. |
