Reconnect the data cables to the rear of the server, as required.
If the CMA is in the way, extend the server approximately 13 cm (5 inches) out
of the front of the rack.
Reconnect the power cables to the power supplies and secure them with the
reclosable straps.
If necessary, reinstall the cables into the CMA and secure them with the
reclosable cable straps.
If you pulled the server out of the rack to make it easier to connect the
cables, push the server into the rack until the slide rail locks (on the front
of the server) engage the slide rail assemblies.
You will hear an audible click when the server is in the normal rack
position.
