Find the Server Serial Number
You need the serial number of the server's chassis to obtain technical support for the server.
Note -
When a motherboard or drive backplane is replaced, the chassis serial number
and part number might need to be programmed into the new component. This action
must be done in a special service mode by trained service personnel.
- Locate the serial number using one of these methods:
- Read the serial
number from a sticker located on the front of the server or another
sticker on the side of the server.
- At the Oracle ILOM prompt, type:
-> show /System
/System
Targets:
In the output look for a line under Properties that identifies
the product serial number. For example:
serial_number = BKL1026F8F
