Install the Drive Backplane
This is a cold-service procedure that must be performed by qualified service
personnel. Power down the server completely before performing this procedure.
| Caution -
This procedure requires that you handle components that are sensitive to
ESD which can cause server components to
fail.
Place the backplane into the disk cage.
Lift the metal spring retainer (1.1) and position the backplane so
that it fits into the two metal brackets that are located on the chassis
side walls (1.2).
Lower the drive backplane into the disk cage so that it engages the
three metal hooks in the disk cage (1.3)
Continue to lower the drive backplane into the disk cage until it is
positioned in all six troughs that are located at the bottom of the disk
cage (1.4) .
Turn the drive backplane captive screw clockwise until the drive
backplane is secure (1.5).
Reconnect the drive backplane power cable to the drive backplane (2).
Reconnect the drive backplane auxiliary power and signal cable to the drive
backplane (4).
Reconnect the SAS cables and the NVMe card cables to the drive backplane (5).
Reinstall all of the storage drives into the storage drive cage.
See Install a Drive.
Install the disk cage cover.
Install all four fan modules.
See Install a Fan Module.
Return the server to operation.
See Returning the Server to Operation.
