Go to main content
SPARC S7-2 Server Service Manual
Exit Print View
Updated: March 2017
Verify the Drive Backplane
  1. At the Oracle ILOM prompt, start the fault management shell.
    -> start /SP/faultmgmt/shell
    Are you sure you want to start /SP/faultmgmt/shell (y/n)? y
    faultmgmtsp>
  2. Type fmadm faulty to check for faults.
    • If faults are reported, see Detecting and Managing Faults .
    • If no faults are reported, then the drive backplane has been replaced successfully.
Related Information
