| Skip Navigation Links | |
| Exit Print View | |
Sun Network QDR InfiniBand Gateway Switch HTML Document Collection for Firmware Version 2.1 |
Preparing to Install the Gateway
Assemble the Optical Fiber Data Cables
Install the Gateway in the Rack
Network Management Troubleshooting Guidelines
Understanding Routing Through the Gateway
Configuring Secure Fabric Management
Administering Gateway Resources
Installing Gateway Supportive Software (Linux)
Creating VNICs Under Gateway Manual Mode (Linux)
Creating VNICs Under Host Manual Mode (Linux)
Creating Virtual IO Adapters (Oracle Solaris)
Controlling Gateway Ports and Parameters
Understanding Oracle ILOM on the Gateway
Upgrading the Gateway Firmware Through Oracle ILOM (CLI)
Upgrade the Gateway Firmware (Web)
V1 and V2c Protocol Command Format
Display the Date and Time (SNMP)
Display the Aggregate Sensors State (SNMP)
Display Power Supply Status (SNMP)
Display Board-Level Voltages (SNMP)
Display Internal Temperatures (SNMP)
Display the Sensor Alarm State (SNMP)
Display Oracle ILOM Sessions (SNMP)
Display the Oracle ILOM Event Log (SNMP)
Checking the Status of Services (SNMP)
Display the HTTP Service Status (SNMP)
Display the HTTPS Service Status (SNMP)
Display the DNS Client Status (SNMP)
Display the SMTP Client Status (SNMP)
Display the NTP Servers (SNMP)
Verifying Other Aspects With Oracle ILOM (SNMP)
Display the Alert Properties (SNMP)
Display Oracle ILOM User Accounts (SNMP)
Display the Remote Log Hosts (SNMP)
Display the Network Management Configuration (SNMP)
Display the System Components (SNMP)
Display the Additional System Component Information (SNMP)
Display the Firmware Version (SNMP)
Display System Identification Properties (SNMP)
Performing General Tasks (SNMP)
Set the Network Time Protocol State (SNMP)
Set the Network Time Protocol Servers (SNMP)
Clear the Oracle ILOM Event Log (SNMP)
Set the Remote Log Hosts (SNMP)
Configure the DNS Client (SNMP)
Configure the SMTP Client (SNMP)
Set the Network Parameters (SNMP)
Set the System Identification Properties (SNMP)
Add an Oracle ILOM User Account (SNMP)
Delete an Oracle ILOM User Account (SNMP)
Managing Other Aspects With Oracle ILOM (SNMP)
Set the HTTP Service State (SNMP)
Set the HTTPS Service State (SNMP)
Enable Alerts to Send SNMP Traps (SNMP)
Enable Alerts to Send PETs (SNMP)
Enable Alerts to Send Email Alerts (SNMP)
Modify Alert SNMP Version (SNMP)
Display Gateway Status LED States (IPMI)
Identify Faults in the Oracle ILOM Event Log
Determining the Alarm State of a Component or System
Determine If a Power Supply Is Faulty
Determine If the Battery Is Faulty
Remove the Gateway From the Rack
Note - You can only display FRU ID information for currently present power supplies.
Note - The entity numbers for the /SYS/PSUx power supply FRU targets might change with different firmware releases or gateway configurations. Verify the power supply entity numbers with the procedure in Display the Entity Numbers.
$ snmpwalk -v2c -c public mc_IP ENTITY-MIB::entPhysicalTable ENTITY-MIB::entPhysicalDescr.1 = STRING: Sun Network QDR InfiniBand Gateway Switch ENTITY-MIB::entPhysicalDescr.2 = STRING: Motherboard ENTITY-MIB::entPhysicalDescr.3 = STRING: Fault Sensor ENTITY-MIB::entPhysicalDescr.4 = STRING: Voltage Sensor ENTITY-MIB::entPhysicalDescr.5 = STRING: Fault Sensor . . . ENTITY-MIB::entPhysicalDescr.46 = STRING: Power Supply FRU . . . ENTITY-MIB::entPhysicalDescr.51 = STRING: Power Supply FRU . . . ENTITY-MIB::entPhysicalVendorType.46 = OID: SNMPv2-SMI::zeroDotZero . . . ENTITY-MIB::entPhysicalVendorType.51 = OID: SNMPv2-SMI::zeroDotZero . . . ENTITY-MIB::entPhysicalContainedIn.46 = INTEGER: 1 . . . ENTITY-MIB::entPhysicalContainedIn.51 = INTEGER: 1 . . . ENTITY-MIB::entPhysicalClass.46 = INTEGER: powerSupply(6) . . . ENTITY-MIB::entPhysicalClass.51 = INTEGER: powerSupply(6) . . . ENTITY-MIB::entPhysicalParentRelPos.46 = INTEGER: 1 . . . ENTITY-MIB::entPhysicalParentRelPos.51 = INTEGER: 2 . . . ENTITY-MIB::entPhysicalName.46 = STRING: /SYS/PSU0 . . . ENTITY-MIB::entPhysicalName.51 = STRING: /SYS/PSU1 . . . $
You can also filter the output of the snmpwalk command for a specific entity number. This is an example of filtering the snmpwalk command output.:
$ snmpwalk -v2c -c public mc_IP ENTITY-MIB::entPhysicalTable | grep -F '.number ='
where number is the entity number.
Note - The manner in which you can filter the output varies according to your operating system.
To filter voltage information for the left power supply (PSU0), use the entity number respective to the /SYS/PSU0 power supply FRU target. This filtering example uses entity number 46:
$ snmpwalk -v2c -c public mc_IP ENTITY-MIB::entPhysicalTable | grep -F '.46 =' ENTITY-MIB::entPhysicalDescr.46 = STRING: Power Supply FRU ENTITY-MIB::entPhysicalVendorType.46 = OID: SNMPv2-SMI::zeroDotZero ENTITY-MIB::entPhysicalContainedIn.46 = INTEGER: 1 ENTITY-MIB::entPhysicalClass.46 = INTEGER: powerSupply(6) ENTITY-MIB::entPhysicalParentRelPos.46 = INTEGER: 1 ENTITY-MIB::entPhysicalName.46 = STRING: /SYS/PSU0 ENTITY-MIB::entPhysicalHardwareRev.46 = STRING: ENTITY-MIB::entPhysicalFirmwareRev.46 = STRING: ENTITY-MIB::entPhysicalSoftwareRev.46 = STRING: 02 ENTITY-MIB::entPhysicalSerialNum.46 = STRING: 001180 ENTITY-MIB::entPhysicalMfgName.46 = STRING: Delta Energy Systems ENTITY-MIB::entPhysicalModelName.46 = STRING: 3002233 ENTITY-MIB::entPhysicalAlias.46 = STRING: A247 ENTITY-MIB::entPhysicalAssetID.46 = STRING: ENTITY-MIB::entPhysicalIsFRU.46 = INTEGER: true(1) $
