| Skip Navigation Links | |
| Exit Print View | |
Sun Network QDR InfiniBand Gateway Switch HTML Document Collection for Firmware Version 2.1 |
Preparing to Install the Gateway
Assemble the Optical Fiber Data Cables
Install the Gateway in the Rack
Network Management Troubleshooting Guidelines
Understanding Routing Through the Gateway
Configuring Secure Fabric Management
Administering Gateway Resources
Installing Gateway Supportive Software (Linux)
Creating VNICs Under Gateway Manual Mode (Linux)
Creating VNICs Under Host Manual Mode (Linux)
Creating Virtual IO Adapters (Oracle Solaris)
Controlling Gateway Ports and Parameters
Understanding Oracle ILOM on the Gateway
Access the Oracle ILOM Shell From the CLI (NET MGT Port)
Access the Oracle ILOM Shell From the CLI (USB Management Port)
/SYS/Switch_Diag, /SYS/Gateway_Mgmt, and /SYS/Fabric_Mgmt Linux Shells
Switch From the Oracle ILOM Shell to the Linux Shell
Switch From the Linux Shell to the Oracle ILOM Shell
Display Faulted System Components (CLI)
Display Gateway Status LEDs States (CLI)
Display the Aggregate Sensors State (CLI)
Display Power Supply Status (CLI)
Display Board-Level Voltages (CLI)
Display Internal Temperatures (CLI)
Display the Oracle ILOM Sessions (CLI)
Checking the Status of Services (CLI)
Display the HTTP Service Status (CLI)
Display the HTTPS Service Status (CLI)
Display the SSL Certificates (CLI)
Display the SNMP Service Status (CLI)
Display the SNMP User Accounts (CLI)
Display the SNMP Service Communities (CLI)
Display the IPMI Service Status (CLI)
Display the DNS Client Status (CLI)
Display the SMTP Client Status (CLI)
Verifying Other Aspects With Oracle ILOM (CLI)
Get Help on an Oracle ILOM Command (CLI)
Get Help on an Oracle ILOM Target Property (CLI)
Display the Alert Properties (CLI)
Display the Oracle ILOM User Accounts (CLI)
Display the Remote Log Hosts (CLI)
Display the Network Management Configuration (CLI)
Display the CLI Session Timeout (CLI)
Display Power Supply FRU ID (CLI)
Display the Firmware Version (CLI)
Display System Identification Properties (CLI)
Performing General Tasks on Oracle ILOM Targets (CLI)
Restart the Management Controller (CLI)
Clear Faulted System Components (CLI)
Clear the Oracle ILOM Event Log (CLI)
Set the Remote Log Hosts (CLI)
Configure the DNS Client (CLI)
Configure the SMTP Client (CLI)
Back Up the Configuration (CLI)
Gateway Configuration Information Backed Up
Restore the Configuration (CLI)
Create a Snapshot of the Gateway State (CLI)
Snapshot Dataset Information (CLI)
Set the Network Management Parameters (CLI)
Set the System Identification Properties (CLI)
Performing Oracle ILOM User Tasks (CLI)
Add an Oracle ILOM User Account (CLI)
Change an Oracle ILOM User's Password and or Role (CLI)
Delete an Oracle ILOM User Account (CLI)
Disable the HTTP Service (CLI)
Enable the HTTPS Service (CLI)
Install a Custom SSL Certificate and Key (CLI)
Remove the Custom SSL Certificate and Key (CLI)
Disable the HTTPS Service (CLI)
Configure the SNMP Service (CLI)
Add SNMP Service User Accounts (CLI)
Modify SNMP Service User Accounts (CLI)
Delete SNMP Service User Accounts (CLI)
Add SNMP Service Communities (CLI)
Modify SNMP Service Communities (CLI)
Delete SNMP Service Communities (CLI)
Download SNMP Service MIBs (CLI)
Disable the SNMP Service (CLI)
Disable the IPMI Service (CLI)
Managing Other Aspects With Oracle ILOM (CLI)
Enable Alerts to Send SNMP Traps (CLI)
Enable Alerts to Send PETs (CLI)
Enable Alerts to Send Email Alerts (CLI)
Set the Oracle ILOM CLI Session Timeout (CLI)
Upgrading the Gateway Firmware Through Oracle ILOM (CLI)
Verify Firmware Integrity (CLI)
Acquire the Gateway Firmware Package (CLI)
Upgrade the Gateway Firmware (CLI)
Upgrade the Gateway Firmware (Web)
Display Gateway Status LED States (IPMI)
Identify Faults in the Oracle ILOM Event Log
Determining the Alarm State of a Component or System
Determine If a Power Supply Is Faulty
Determine If the Battery Is Faulty
Remove the Gateway From the Rack
The Oracle ILOM event message log contains Oracle ILOM events that happened to or were initiated by the management controller. Example events include user login, sensor state change, configuring of syslog servers, and so on. You can view these events using the Oracle ILOM show command for the /SP/logs/event/list target.
Note - The most recent events are listed at the top of the log.
-> show /SP/logs/event/list
/SP/logs/event/list
Targets:
Properties:
Commands:
cd
show
ID Date/Time Class Type Severity
94 Tue Oct 9 01:15:13 2012 Audit Log minor
root : Open Session : object = /session/type : value = shell : success
93 Tue Oct 9 01:13:51 2012 Audit Log minor
test : Close Session : object = /session/type : value = www : success
92 Tue Oct 9 00:59:44 2012 Audit Log minor
->The columns of the output are:
ID – The sequence number of the event, starting with 1.
Date/Time – The day and time the event occurred.
Class – Can be Audit, IPMI, Chassis, or Fault.
Type – Can be Log, State, Action, Fault, or Repair.
Severity – Can be Debug, Down, Critical, Major, or Minor.
-> show /SP/logs/event/list Class==class Type==type
where class and type are from the table in Oracle ILOM Log Entry Filters.
For example, to display the IPMI log events, type:
-> show /SP/logs/event/list Class==IPMI Type==Log ID Date/Time Class Type Severity ----- ------------------------ -------- -------- -------- 61600 Mon Jan 14 14:36:55 2013 IPMI Log critical ID = 16cf : 01/14/2013 : 14:36:55 : OEM sensor : CABLE_CONN_STAT : State Deasserted 61599 Mon Jan 14 14:36:45 2013 IPMI Log critical ID = 16ce : 01/14/2013 : 14:36:45 : OEM sensor : CABLE_CONN_STAT : State Asserted 61594 Wed Jan 9 11:29:03 2013 IPMI Log critical ID = 16cd : 01/09/2013 : 11:29:03 : OEM sensor : PSU0/ALERT : State Deass erted . . . ->
Note - Refer to Gateway Service, detecting and managing faults, for more information about filtering the Oracle ILOM event log for fault information.
The Q key quits.
Gateway Service, identifying faults in the event log
