Skip Navigation Links | |
Exit Print View | |
Sun Network QDR InfiniBand Gateway Switch HTML Document Collection for Firmware Version 2.1 |
Preparing to Install the Gateway
Assemble the Optical Fiber Data Cables
Install the Gateway in the Rack
Network Management Troubleshooting Guidelines
Understanding Routing Through the Gateway
Display the Switch Chip Port to QSFP Connector Mapping
Locate a InfiniBand Device and Connector From the GUID and Port
Locate a Switch Chip or Connector From the GUID and Port
Display Switch Chip Boot Status
Display Connectors Configured With Autodisable Functionality
Display Switch Chip Port Status
Display Switch Chip Port Counters
Autodisabling Ports and Connectors
Add Connectors to the Autodisable List
Delete Connectors From the Autodisable List
Configuring Secure Fabric Management
Administering Gateway Resources
Installing Gateway Supportive Software (Linux)
Creating VNICs Under Gateway Manual Mode (Linux)
Creating VNICs Under Host Manual Mode (Linux)
Creating Virtual IO Adapters (Oracle Solaris)
Controlling Gateway Ports and Parameters
Understanding Oracle ILOM on the Gateway
Upgrading the Gateway Firmware Through Oracle ILOM (CLI)
Upgrade the Gateway Firmware (Web)
Display Gateway Status LED States (IPMI)
Identify Faults in the Oracle ILOM Event Log
Determining the Alarm State of a Component or System
Determine If a Power Supply Is Faulty
Determine If the Battery Is Faulty
Remove the Gateway From the Rack
Inspect the condition of the cable and connectors at both ends, and replace if necessary. Refer to Gateway Service, servicing cables.
FabMan@gateway_name->enableswitchport --automatic port|connector
where:
port is the number of the port (5 to 36).
connector is the number of the QSFP connector (0A to 15B).
For example:
FabMan@gateway_name->enableswitchport --automatic 0A
Do not use the --automatic option when you reenable the port. See Enable a Switch Chip Port.
Gateway Reference, enableswitchport command
