Skip Navigation Links | |
Exit Print View | |
Sun Network QDR InfiniBand Gateway Switch HTML Document Collection for Firmware Version 2.1 |
Preparing to Install the Gateway
Assemble the Optical Fiber Data Cables
Install the Gateway in the Rack
Network Management Troubleshooting Guidelines
Understanding Routing Through the Gateway
Configuring Secure Fabric Management
Administering Gateway Resources
Installing Gateway Supportive Software (Linux)
Creating VNICs Under Gateway Manual Mode (Linux)
Creating VNICs Under Host Manual Mode (Linux)
Creating Virtual IO Adapters (Oracle Solaris)
Controlling Gateway Ports and Parameters
Understanding Oracle ILOM on the Gateway
Upgrading the Gateway Firmware Through Oracle ILOM (CLI)
Upgrade the Gateway Firmware (Web)
Display Gateway Status LED States (IPMI)
Identify Faults in the Oracle ILOM Event Log
Determining the Alarm State of a Component or System
Determine If a Power Supply Is Faulty
Determine If the Battery Is Faulty
Remove the Gateway From the Rack
SUN-DCS-IB-MIB MIB OID Command Syntax
Subnet Manager Agent Data Port OIDs
Understanding Performance Manager Agent OIDs
PMA Extended Port Counters Table OIDs
Understanding Gateway Specific OIDs
SUN-FABRIC-MIB MIB OID Command Syntax
Fabric Management Element OIDs
Fabric Management External Element OIDs
Fabric Management Gateway OIDs
Fabric Trap Configuration OIDs
Hardware Trap Configuration OIDs
SUN-ILOM-CONTROL-MIB MIB OID Command Syntax
SUN-PLATFORM-MIB MIB OID Command Syntax
Understanding MIB Physical OIDs
Physical Class Extension Table OIDs
Sun Platform Sensor Table OIDs
Sun Platform Numeric Sensor Table OIDs
Understanding the ENTITY-MIB MIB OIDs
This table lists fabric element object identifiers supported by the SUN-FABRIC-MIB MIB.
