| Skip Navigation Links | |
| Exit Print View | |
Sun Network QDR InfiniBand Gateway Switch HTML Document Collection for Firmware Version 2.1 |
Floor and Underfloor Delivery of Data Cables
Overhead Delivery of Data Cables
Preparing to Install the Gateway
Assemble the Optical Fiber Data Cables
Install the Gateway in the Rack
Network Management Troubleshooting Guidelines
Understanding Routing Through the Gateway
Configuring Secure Fabric Management
Administering Gateway Resources
Installing Gateway Supportive Software (Linux)
Creating VNICs Under Gateway Manual Mode (Linux)
Creating VNICs Under Host Manual Mode (Linux)
Creating Virtual IO Adapters (Oracle Solaris)
Controlling Gateway Ports and Parameters
Understanding Oracle ILOM on the Gateway
Upgrading the Gateway Firmware Through Oracle ILOM (CLI)
Upgrade the Gateway Firmware (Web)
Display Gateway Status LED States (IPMI)
Identify Faults in the Oracle ILOM Event Log
Determining the Alarm State of a Component or System
Determine If a Power Supply Is Faulty
Determine If the Battery Is Faulty
Remove the Gateway From the Rack
Proper data cable installation requires the following:
Plan the cable routes and cable length needs.
Identify problematic cable route bends, minimizing the length of continuous vertical runs to no more than 2 meters (7 feet), and specify hardware to support cable routing.
Carry the entire cable to the points of connection and unroll the cable from the first connection point to the second
Keep the coil closed and pause to enable the cable to relax as it is unrolled and moved through turns.
Ensure that cable route turns are larger than 85 mm (3.4 inches) radius for optical cables and 127 mm (5 inches) radius for copper cables.
Find alternative routes for turns that are tighter.
Secure the cable to hard points and bundle it with soft, hook-and-loop fasteners.
See Data Cable Bundling.
Mediate the slack between securing points to maintain minimal cable tension and proper support.
See Floor and Underfloor Delivery of Data Cables and Overhead Delivery of Data Cables.
Label the ends of cables to identify their routes.
Rest the cable connectors on a stable surface when they are not connected.
