Skip Navigation Links
Exit Print View
Sun Datacenter InfiniBand Switch 36 HTML Document Collection for Firmware Version 2.1
search filter icon
search icon
Document Information
Using This Documentation
Product Notes
Related Documentation
Feedback
Access to Oracle Support
Installation
Understanding the Switch
Switch Overview
Physical Specifications
Environmental Requirements
Acoustic Noise Emissions
Electrical Specifications
NET MGT Connector and Pins
InfiniBand QSFP Connector and Pins
Understanding Cabling
Routing Service Cables
Understanding InfiniBand Cabling
Preparing to Install the Switch
Installation Preparation
Installation Responsibilities
Installation Sequence
Assemble the Optical Fiber InfiniBand Cables
Route the InfiniBand Cables
Installing the Switch
Install the Switch in the Rack
Powering On the Switch
Connecting InfiniBand cables
Administration
Troubleshooting the Switch
Switch Hardware Problems
InfiniBand Fabric Problems
Network Management Troubleshooting Guidelines
Understanding Routing Through the Switch
Switch GUIDs Overview
Configuration Overview
Oracle ILOM Command Overview
Hardware Command Overview
InfiniBand Command Overview
Administering the Chassis
Monitoring the Chassis
Controlling the Chassis
Monitoring the I4 Switch Chip
Monitoring the Subnet Manager
Configuring Secure Fabric Management
Remote Management
Understanding Oracle ILOM on the Switch
Oracle ILOM Overview
Supported Features
CLI Overview
Upgrading the Switch Firmware Through Oracle ILOM (CLI)
Web Interface Overview
Upgrade the Switch Firmware (Web)
Using the Fabric Monitor
Access the Fabric Monitor
Fabric Monitor Features
Rear Panel Diagram Overview
InfiniBand Connector Status Window
System Info Tab
Sensor Info Tab
IB Performance Tab
IB Port Map Tab
Subnet Manager Tab
Control Panel Function
Chassis Parameters and Status
InfiniBand Connector Parameters and Status
Switch Connector Parameters and Status
I4 Switch Chip Port Parameters and Status
SNMP Overview
Understanding SNMP Commands
Administering Hardware (IPMI)
ipmitool Overview
Display Switch Status LED States (IPMI)
Enable the Locator LED (IPMI)
cd Command
create Command
delete Command
dump Command
exit Command (Oracle ILOM)
help Command (Oracle ILOM)
load Command
reset Command
set Command
show Command
version Command (Oracle ILOM)
Service
Detecting and Managing Faults
Interpreting Status LEDs
Managing Faulty Components
Identify Faults in the Oracle ILOM Event Log
Determining the Alarm State of a Component or System
Evaluating Sensor Alarms
Accessing CLI Prompts
Replaceable Components
Suggested Tools for Service
Servicing Power Supplies
Determine If a Power Supply Is Faulty
Inspecting a Power Supply
Power Off a Power Supply
Remove a Power Supply
Install a Power Supply
Power On a Power Supply
Servicing Fans
Determine If a Fan Is Faulty
Inspecting a Fan
Remove a Fan
Install a Fan
Servicing InfiniBand Cables
Inspecting the InfiniBand Cables
Remove an InfiniBand Cable
Install an InfiniBand Cable
Servicing the Battery
Determine If the Battery Is Faulty
Remove the Switch From the Rack
Replace the Battery
Reference
autodisable Command
checkboot Command
checkpower Command
checktopomax Command
checkvoltages Command
connector Command
create_ipoib Command
createfabric Command
dcsport Command
delete_ipoib Command
disablecablelog Command
disablelinklog Command
disablesm Command
disableswitchport Command
enablecablelog Command
enablelinklog Command
enablesm Command
enableswitchport Command
env_test Command
exit Command (Hardware)
fdconfig Command
fwverify Command
generatetopology Command
getfanspeed Command
getmaster Command
getportcounters Command
getportstatus Command
help Command (Hardware)
listlinkup Command
localmkeypersistence Command
matchtopology Command
setcontrolledhandover Command
setmsmlocationmonitor Command
setsmmkey Command
setsmpriority Command
setsmrouting Command
setsubnetprefix Command
showdisk Command
showfree Command
showfruinfo Command
showpsufru Command
showsmlog Command
showtemps Command
showtopology Command
showunhealthy Command
smconfigtest Command
smnodes Command
smpartition Command
smsubnetprotection Command
version Command (Hardware)
ibdiagnet Command
ibhosts Command
ibnetdiscover Command
ibnetstatus Command
ibnodes Command
ibportstate Command
ibroute Command
ibrouters Command
ibstat Command
ibswitches Command
ibtracert Command
perfquery Command
saquery Command
smpquery Command
Understanding SNMP MIB OIDs
OID Tables Overview
Understanding the ENTITY-MIB MIB OIDs
Index
Use this table to determine chassis status with the FM. Find the parameter or status in the left column, then perform the steps from left to right.
Parameter or Status to Monitor
Action in Status Pane
Information Location
Battery voltage.
Click Sensor Info tab.
Look in the first column, Voltage Sensors, in the middle.
Chassis FRU description.
Click System Info tab.
Look in the second column, Chassis FRU, at the top.
Chassis part number.
Look in the second column, Chassis FRU, in the middle.
Chassis serial number.
Chassis temperatures.
Look in the third column, Temperature Sensors.
Controlled handover state.
Click Subnet Manager tab.
Look in the second column, Local SM Settings, in the middle.
Fan presence.
Look in the second column, Fan Sensors, second column.
Fan speed.
Look in the second column, Fan Sensors, third column.
Fan status.
Look in the second column, Fan Sensors, fourth column.
I4 switch chip firmware version.
Look in the first column, Core IB Switch, in the middle.
I4 switch chip GUID.
Look in the first column, Core IB Switch, at the top.
I4 switch chip historic aggregate bandwidth.
Click Show Aggregate Bandwidth Chart.
Look in the center.
I4 switch chip LID.
Look in the first column, Active SM Info, at the top.
I4 switch chip status.
Look in the third column, IB Device Sensors, at the top.
I4 switch chip temperature.
Look in the third column, Temperature Sensors, at the bottom.
I4 switch chip voltage.
Look in the first column, Voltage Sensors, at the bottom.
Main board voltages.
Look in the first column, Voltage Sensors.
Management controller BIOS version.
Look in the first column, Service Processor, at the bottom.
Management controller firmware version.
Look in the second column, Firmware.
Management controller serial number.
Look in the first column, Service Processor, at the top.
Power supply presence.
Look in the second column, Power Sensors, second column.
Power supply line voltage presence.
Look in the second column, Power Sensors, third column.
Power supply status.
Look in the second column, Power Sensors, fourth column.
Subnet Manager controlled handover.
Subnet Manager GUID.
Subnet Manager LID.
Subnet Manager priority.
Look in the first column, Active SM Info, in the middle.
Subnet Manager routing algorithm.
Subnet Manager status.
Look in the second column, Local SM Settings, at the top.
Subnet Manager subnet prefix.
Look in the second column, Local SM Settings, at the bottom.
Related Information
