Skip Navigation Links | |
Exit Print View | |
Sun Datacenter InfiniBand Switch 36 HTML Document Collection for Firmware Version 2.1 |
InfiniBand QSFP Connector and Pins
Understanding InfiniBand Cabling
Preparing to Install the Switch
Assemble the Optical Fiber InfiniBand Cables
Install the Switch in the Rack
Network Management Troubleshooting Guidelines
Understanding Routing Through the Switch
Configuring Secure Fabric Management
Understanding Oracle ILOM on the Switch
Upgrading the Switch Firmware Through Oracle ILOM (CLI)
Upgrade the Switch Firmware (Web)
InfiniBand Connector Status Window
InfiniBand Connector Parameters and Status
Switch Connector Parameters and Status
I4 Switch Chip Port Parameters and Status
Display Switch Status LED States (IPMI)
Identify Faults in the Oracle ILOM Event Log
Determining the Alarm State of a Component or System
Determine If a Power Supply Is Faulty
Inspecting the InfiniBand Cables
Determine If the Battery Is Faulty
Remove the Switch From the Rack
This figure provides an example of the Sensor Info tab.
The Sensor Info tab displays status information regarding the switch sensors. The information is categorized in these groups:
Voltage Sensors – Assorted voltages on the main board
Power Sensors – Presence, AC presence, and status for both power supply slots
Fan Sensors – Presence, RPM, and status for each fan slot
Temperature Sensors – Back, front, management controller, and I4 switch chip
IB Device Sensors – I4 switch chip status
