Skip Navigation Links | |
Exit Print View | |
Sun Datacenter InfiniBand Switch 36 HTML Document Collection for Firmware Version 2.1 |
InfiniBand QSFP Connector and Pins
Understanding InfiniBand Cabling
Preparing to Install the Switch
Assemble the Optical Fiber InfiniBand Cables
Install the Switch in the Rack
Network Management Troubleshooting Guidelines
Understanding Routing Through the Switch
Configuring Secure Fabric Management
Understanding Oracle ILOM on the Switch
Oracle ILOM Targets and Descriptions
Oracle ILOM General System Targets and Properties
Oracle ILOM Fan Targets and Properties
Oracle ILOM Indicator Targets and Properties
Oracle ILOM Temperature Targets and Properties
Oracle ILOM Voltage Targets and Properties
Oracle ILOM Voltage State Targets and Properties
Oracle ILOM General Targets and Properties
Oracle ILOM Service Targets and Properties
Oracle ILOM User and Session Targets and Properties
Upgrading the Switch Firmware Through Oracle ILOM (CLI)
Upgrade the Switch Firmware (Web)
Display Switch Status LED States (IPMI)
Identify Faults in the Oracle ILOM Event Log
Determining the Alarm State of a Component or System
Determine If a Power Supply Is Faulty
Inspecting the InfiniBand Cables
Determine If the Battery Is Faulty
Remove the Switch From the Rack
This table lists the Oracle ILOM /SYS/PSUx targets and their properties. Targets without properties are not listed.
Note - The /SYS/PSUx target is only available for currently present power supplies.
