Skip Navigation Links | |
Exit Print View | |
Sun Datacenter InfiniBand Switch 36 HTML Document Collection for Firmware Version 2.1 |
InfiniBand QSFP Connector and Pins
Understanding InfiniBand Cabling
Preparing to Install the Switch
Assemble the Optical Fiber InfiniBand Cables
Install the Switch in the Rack
Network Management Troubleshooting Guidelines
Understanding Routing Through the Switch
Display Subnet Manager Location History
Display the Secret M_Key Configuration
Verify the Subnet Manager Configuration Integrity
Display the Subnet Manager Log
Set the Subnet Manager Priority
Enable Subnet Manager Controlled Handover
Set the Subnet Manager Readable Management Key
Clear the Subnet Manager Readable Management Key
Set the Subnet Manager Routing Algorithm
Configuring Secure Fabric Management
Prepare for Secret M_Key Functionality
Add Secret M_Keys to the Configuration
Delete Secret M_Keys From the Configuration
Configure a Local Secret M_Key
Enable or Disable Secret M_Key Persistence
Enable or Disable Secret M_Key Functionality
Considering Situations In Regard to Secret M_Key
Add a New Subnet Manager to the Secret M_Key Fabric
Merge Subnets Into One Secret M_Key Fabric
Secret M_Key and Firmware Upgrade and Downgrade Guidelines
Understanding Oracle ILOM on the Switch
Upgrading the Switch Firmware Through Oracle ILOM (CLI)
Upgrade the Switch Firmware (Web)
Display Switch Status LED States (IPMI)
Identify Faults in the Oracle ILOM Event Log
Determining the Alarm State of a Component or System
Determine If a Power Supply Is Faulty
Inspecting the InfiniBand Cables
Determine If the Battery Is Faulty
Remove the Switch From the Rack
FabMan@switch_name->smsubnetprotection start -addonly FabMan@switch_name->
FabMan@switch_name->smsubnetprotection add m_key
where m_key is the management key (16 hexadecimal digits).
Note - There is a maximum of 10 secret M_Keys for the configuration.
For example:
FabMan@switch_name->smsubnetprotection add 0x00abcdefabcdef01 Mkey added FabMan@switch_name->smsubnetprotection add 0x00abcdefabcdef02 Mkey added FabMan@switch_name->
FabMan@switch_name->smsubnetprotection set-current m_key
For example:
FabMan@switch_name->smsubnetprotection set-current 0x00abcdefabcdef01 Mkey 0x00abcdefabcdef01 updated FabMan@switch_name->
Note - You can only set an M_Key that has been added to the configuration.
FabMan@switch_name->smsubnetprotection list modified # File_format_version_number 1 # Sun DCS IB mkey config file # This file is generated, do not edit # secretmkey=enabled # nodeid=mnm # time=15 Dec 03:38:33 # checksum=0 #! commit_number : 2 Mkey Untrusted Mkey Smkey Attribute ------------------ ------------------ ------------------ --------- 0x00abcdefabcdef01 0x1aa45124fee612ae 0x15fc26aea300f831 0x00abcdefabcdef02 0x4ccd8230de6cd348 0x3fc7e6ad701a8a2a S FabMan@switch_name->
Note - The S in the Attribute column means that M_Key is in standby state, and is to become the current secret M_Key.
FabMan@switch_name->smsubnetprotection commit FabMan@switch_name->
The configuration is distributed to the trusted standby Subnet Managers and the current secret M_Key to the InfiniBand Fabric.
Switch Reference, smsubnetprotection command
