Skip Navigation Links | |
Exit Print View | |
Sun Datacenter InfiniBand Switch 36 HTML Document Collection for Firmware Version 2.1 |
InfiniBand QSFP Connector and Pins
Understanding InfiniBand Cabling
Preparing to Install the Switch
Assemble the Optical Fiber InfiniBand Cables
Install the Switch in the Rack
Network Management Troubleshooting Guidelines
Understanding Routing Through the Switch
Display Subnet Manager Location History
Display the Secret M_Key Configuration
Verify the Subnet Manager Configuration Integrity
Display the Subnet Manager Log
Set the Subnet Manager Priority
Enable Subnet Manager Controlled Handover
Set the Subnet Manager Readable Management Key
Clear the Subnet Manager Readable Management Key
Set the Subnet Manager Routing Algorithm
Configuring Secure Fabric Management
Prepare for Secret M_Key Functionality
Create the Secret M_Key Configuration
Add Secret M_Keys to the Configuration
Delete Secret M_Keys From the Configuration
Enable or Disable Secret M_Key Persistence
Enable or Disable Secret M_Key Functionality
Considering Situations In Regard to Secret M_Key
Add a New Subnet Manager to the Secret M_Key Fabric
Merge Subnets Into One Secret M_Key Fabric
Secret M_Key and Firmware Upgrade and Downgrade Guidelines
Understanding Oracle ILOM on the Switch
Upgrading the Switch Firmware Through Oracle ILOM (CLI)
Upgrade the Switch Firmware (Web)
Display Switch Status LED States (IPMI)
Identify Faults in the Oracle ILOM Event Log
Determining the Alarm State of a Component or System
Determine If a Power Supply Is Faulty
Inspecting the InfiniBand Cables
Determine If the Battery Is Faulty
Remove the Switch From the Rack
When a switch (or gateway) from an InfiniBand subnet using secret M_Key functionality is brought into a fabric using a different secret M_Key configuration, the switch is isolated from traffic because the secret M_Keys mismatch. In this situation, you must provide a recognized secret M_Key to the added switch, so that the switch is merged into the fabric and secured with the current secret M_key configuration.
Conversely, by manually changing the current secret M_Key of a switch (or gateway) to a persistent value not in the secret M_Key configuration, you isolate the switch (or gateway) from the fabric.
FabMan@switch_name->smsubnetprotection setlocalsecretmkey m_key
where m_key is the management key (16 hexadecimal digits). For example:
FabMan@switch_name->smsubnetprotection setlocalsecretmkey 0x00abcdefabcdef04 Local mkey: 0xabcdefabcdef04 Attribute: secret FabMan@switch_name->
See:
Switch Reference, smsubnetprotection command
