Go to main content
oracle home
Sun Network QDR InfiniBand Gateway Switch Documentation Supplement for Firmware Version 2.2
Exit Print View
Search Term
Search Scope:
This Document
Entire Library
Documentation Home
Sun Network QDR InfiniBand Gateway Switch ...
Updated: September 2016
Document Information
Using This Documentation
Product Documentation Library
Feedback
Supplementing the Installation Guide
Electrical Specifications
IB Node Description
Supplementing the Administration Guide
Understanding Routing Through the Gateway
QSFP Connectors and Link LEDs to Switch Chip Port Routes
VNIC Allocation on the Gateway
Understanding the Toolbox CLI
Performing Basic Toolbox CLI Tasks
Related Information
Toolbox CLI Overview
Start the Toolbox CLI
Display the Toolbox CLI Version
Display the Toolbox CLI Settings
Modify the Toolbox CLI Settings
Toolbox CLI Settings Properties
Enable or Disable the Toolbox CLI Daemon
Administering the Fabric Configuration (Toolbox CLI)
Display the Fabric Configuration File (Toolbox CLI)
Fabric Configuration Wizard Overview
Run the Fabric Configuration Wizard (Toolbox CLI)
Add a Switch to the Fabric Configuration (Toolbox CLI)
Remove a Switch From the Fabric Configuration (Toolbox CLI)
Distribute the Fabric Configuration (Toolbox CLI)
Administering Partitions (Toolbox CLI)
Display a Partition (Toolbox CLI)
Display the Ports of All Partitions (Toolbox CLI)
Display the Partitions With a Particular Port (Toolbox CLI)
Create a Partition (Toolbox CLI)
Modify a Partition (Toolbox CLI)
Add a Port to a Partition (Toolbox CLI)
Modify a Port of a Partition (Toolbox CLI)
Remove a Port From a Partition (Toolbox CLI)
Remove a Partition (Toolbox CLI)
Administering Subnet Managers (Toolbox CLI)
Display Subnet Manager Status (Toolbox CLI)
Enable or Disable a Subnet Manager (Toolbox CLI)
Configure a Subnet Manager (Toolbox CLI)
Administering Switches (Toolbox CLI)
Display Switch Information (Toolbox CLI)
Display Switch Backups (Toolbox CLI)
Back Up a Switch Configuration (Toolbox CLI)
Disable a Switch (Toolbox CLI)
Restore a Switch (Toolbox CLI)
Administering Hosts (Toolbox CLI)
Display Host Partition Information (Toolbox CLI)
Display All Hosts in the Fabric (Toolbox CLI)
Display Hosts Visible From a Node (Toolbox CLI)
Replace a GUID Manually (Toolbox CLI)
Replace a GUID Automatically (Toolbox CLI)
Administering Logs (Toolbox CLI)
Display the Local Port Log (Toolbox CLI)
Display the Remote Switch Port Log (Toolbox CLI)
Display the Switch Event Log (Toolbox CLI)
Configure Email Alerts (Toolbox CLI)
Supplementing the Oracle ILOM Document
Oracle ILOM Targets and Descriptions
Oracle ILOM General Targets and Properties
Oracle ILOM Client Targets and Properties
Oracle ILOM Service Targets and Properties
Oracle ILOM User and Session Targets and Properties
Oracle ILOM Legacy Targets and Properties
Switch From the Oracle ILOM Shell to the Linux Shell
Understanding the Oracle ILOM Web Interface
Oracle ILOM Web Interface Overview
Oracle ILOM Web Interface Translation
Supplementing the Service Manual
Battery Service Sequence
Supplementing the Command Reference
createlag Command
Syntax
Description
Options
Example
env_test Command
Syntax
Description
Example
fwverify Command
Syntax
Description
Example
showvlan Command
Syntax
Description
Example
showvnics Command
Syntax
Description
Example
smpartition Command
Syntax
Description
Options
Example
smsubnetprotection Command
Syntax
Description
Options
Example
toolbox Command
Syntax
Description
Example
Understanding Toolbox CLI Commands
Toolbox CLI Command Construct
api-key Object Command
backups Object Command
config Object Commands
daemon Object Command
hosts Object Commands
log Object Command
mkey Object Command
partition Object Commands
settings Object Commands
sm Object Commands
switch Object Commands
switches Object Command
version Object Command
Index
Index A
Index B
Index C
Index D
Index E
Index F
Index H
Index I
Index L
Index M
Index N
Index O
Index P
Index R
Index S
Index T
Index V
Language:
English
September 2016
Provides supplemental information for gateway firmware version 2.2.
Feedback
IB Node Description
Related Information
createlag Command
Syntax
Description
Options
Example
env_test Command
Syntax
Description
Example
fwverify Command
Syntax
Description
Example
showvlan Command
Syntax
Description
Example
showvnics Command
Syntax
Description
Example
smpartition Command
Syntax
Description
Options
Example
Syntax
Description
Options
Example
toolbox Command
Syntax
Description
Example
log Object Command
mkey Object Command
sm Object Commands
Index
A
B
C
D
E
F
H
I
L
M
N
O
P
R
S
T
V
