Go to main content
Sun Network QDR InfiniBand Gateway Switch Documentation Supplement for Firmware Version 2.2
Exit Print View
Updated: September 2016
Back Up a Switch Configuration (Toolbox CLI)
The backup operation copies the backup file to every switch in the Toolbox CLI fabric configuration file.
Note -  The command requires you to provide a passphrase, and the ilom-admin user's password as security measures.
  • In the Toolbox CLI, back up the switch configuration..
    [toolbox-cli] set config backup switch=name|all
    where name is the host name of the switch hosting the Subnet Manager. For example, to back up the switch with host name nsn178-158, type:
    [toolbox-cli] set config backup switch=nsn178-158
    passphrase: passphrase
    The backup will use passphrase 'p******'. Do you want to continue? (y/n): y
    ilom-admin password: password
    Copying ilom backup from nsn178-158 to nsn178-159... [OK]
    Copying ilom backup from nsn178-158 to nsn178-157... [OK]
    [toolbox-cli]
    For example, to back up all switches in the toolbox fabric configuration file, type:
    [toolbox-cli] set config backup all
    The backup will use passphrase 'w***************'. Do you want to continue? (y/n): y
    Copying ilom backup from nsn178-159 to nsn178-158... [OK]
    Copying ilom backup from nsn178-159 to nsn178-157... [OK]
    Copying ilom backup from nsn178-157 to nsn178-158... [OK]
    Copying ilom backup from nsn178-157 to nsn178-159... [OK]
    [toolbox-cli]
Related Information
