Toolbox CLI commands are constructed from five types of components, in this format:
action1 object1 [action2|object2|option][option][option]....
where:
action1 is the primary action performed on object1.
object1 is the object that action1 acts upon.
action2 is the secondary action performed under the condition of object2.
object2 is the object that sets a condition to either action1 or action2.
option is a parameter that is affected or applied with the command.
To simplify finding information about a command, the command reference is organized alphabetically by the object (object1 of the command), the second word of the command construct.
Each object has a table that lists what you are able to do with the object, and the command to achieve that goal.
