Go to main content
Sun Network QDR InfiniBand Gateway Switch Documentation Supplement for Firmware Version 2.2
Exit Print View
Updated: September 2016
hosts Object Commands
Description
Syntax
Display the IB hosts.
show hosts
Display the IB hosts in a partition.
show hosts pname=partition_name|pkey=P_Key
Display the IB hosts in the fabric.
show hosts fabric
Display the IB hosts visible to a node or GUID.
show hosts visible-from nodedesc=node_description|nodeguid=node_guid|portguid=port_guid
where:
  • partition_name is the name of the partition.
  • P_Key is the partition key for the partition.
  • node_description is the node description.
  • node_guid is the node GUID.
  • port_guid is the port GUID.
Related Information
