Go to main content
Sun Network QDR InfiniBand Gateway Switch Documentation Supplement for Firmware Version 2.2
Exit Print View
Updated: September 2016
Remove a Switch From the Fabric Configuration (Toolbox CLI)
  1. In the Toolbox CLI, remove a switch from the fabric configuration.
    [toolbox-cli] remove switch ip=IP_address|name=switch_name
    where:
    • IP_address is the IP address of the management controller of the switch.
    • switch_name is the host name of the switch.
    For example, to remove the switch with host name scao04sw-iba0 from the fabric configuration, type:
    [toolbox-cli] remove switch name=scao04sw-iba0
    Are you sure you want to remove switch 'name="scao04sw-iba0"'? (y/n): y
    Updating fabric conf file: /etc/toolbox/conf/fabric.conf...  [OK]
  2. Restart the toolbox daemon.
    See Enable or Disable the Toolbox CLI Daemon.
Related Information
