Go to main content
Sun Network QDR InfiniBand Gateway Switch Documentation Supplement for Firmware Version 2.2
Exit Print View
Updated: September 2016
Disable a Switch (Toolbox CLI)
Note -  You cannot disable the switch which you are running the toolbox on.
  • In the Toolbox CLI, disable a switch.
    [toolbox-cli] set config disable ip=IP_address|switch=name new_mkey=M_Key
    where:
    • IP_address is the IP addres of the management controller of the switch.
    • name is the host name of the switch hosting the Subnet Manager.
    • M_Key is the new management key.
    For example, to disable the switch with host name nsn178-158 with new management key random (optionally this can be overwritten to a custom value), type:
    [toolbox-cli] set config disable switch=nsn178-158 new_mkey=random
    Switch nsn178-158 will be disabled (5 backups found). Do you want to continue?(y/n) y
    Disabling toolbox user and removing associated keys...  [OK]
    Verifying SM states in fabric...  [OK]
    Acquiring Global Lock... [OK]
    Protecting Fabric(s) based on config provided ... [OK]
    Determining Master SM node... [OK] : "nsn178-159"
    Gathering fabric data... [OK]
    Releasing Global Lock... [OK]
    Updating fabric conf file: /etc/toolbox/conf/fabric.conf...  [OK]
    Verifying Switch FW versions in fabric...  [OK]
    [toolbox-cli]
Related Information
