Go to main content
Sun Network QDR InfiniBand Gateway Switch Documentation Supplement for Firmware Version 2.2
Exit Print View
Updated: September 2016
Display Hosts Visible From a Node (Toolbox CLI)
Note -  This command also displays the P_Keys the node is visible from.
  • In the Toolbox CLI, display the hosts visible from a particular node.
    [toolbox-cli] show hosts visible-from nodesdesc='description'|nodeguid=GUID|portguid=GUID
    where:
    • description is the entire node description string.
    • GUID is either the node GUID or the port GUID.
    For example, to display the hosts visible from the node with port GUID 0x0002c90300089240, type:
    [toolbox-cli] show hosts visible-from portguid=0x0002c90300089240
    NODE DESCRIPTION    MT25408 ConnectX Mellanox Technologies
    NODE GUID           0x0010e00001631b00
    PKEYS               Default(7fff)
    GUID                   NODE DESCRIPTION                                            PKEYS
    0x002128b81684c000     SUN IB QDR GW switch nsn156-81 10.134.156.81 Bridge 0       Default(7fff)
    0x002128ebca1ec000     SUN IB QDR GW switch nsn156-102 10.134.156.102 Bridge 0     Default(7fff)
    0x002128b81684c040     SUN IB QDR GW switch nsn156-81 10.134.156.81 Bridge 1       Default(7fff)
    0x0002c9030008e136     nsn156-54 mlx4_0                                            nm2-box1(3342), Default(7fff)
    0x002128ebca1ec040     SUN IB QDR GW switch nsn156-102 10.134.156.102 Bridge 1     Default(7fff)
    [toolbox-cli]
Related Information
