Go to main content
Sun Network QDR InfiniBand Gateway Switch Documentation Supplement for Firmware Version 2.2
Exit Print View
Updated: September 2016
Remove a Port From a Partition (Toolbox CLI)
  1. In the Toolbox CLI, remove a port from the partition.
    [toolbox-cli] set partition name=name|pkey=P_Key remove port portguid=GUID
    where:
    • name is the partition name.
    • P_Key is the partition key.
    • GUID is the port GUID.
    For example, to remove the port with GUID 0x0002c90300089240 from the partition with P_Key 1122, type:
    [toolbox-cli] set partition pkey=1122 remove port portguid=0x0002c90300089240
    Are you sure you want to remove partition port 'portguid="0x0002c90300089240"'? (y/n): y
    [toolbox-cli]
    There is also a "no confirm" mode where you can specify a -y flag when removing a partition to disable the confirmation prompt.
  2. Verify that the port was removed.
    [toolbox-cli] show partition pkey=1122 ports
    PKEY    : 1122
    FLAGS   : ipoib, rate=4, sl=5
    GUID                   MEMBER
    0x0002c903000891ac     full
    [toolbox-cli]
Related Information
