Go to main content
Sun Network QDR InfiniBand Gateway Switch Documentation Supplement for Firmware Version 2.2
Exit Print View
Updated: September 2016
Replace a GUID Automatically (Toolbox CLI)
  1. In the Toolbox CLI, enable automatic GUID replacement.
    [toolbox-cli] set settings GUID_REPLACEMENT=1
    Done. Restart daemon for changes to take effect.
    [toolbox-cli]
  2. (Optional) Enable further functionality.
    • Write to the port log when a port is disabled or enabled.
      [toolbox-cli] set settings PORT_DISABLED_ALERTS=1
      [toolbox-cli]
    • Write to the port log when an HCA is replaced.
      [toolbox-cli] set settings HCA_REPLACEMENT_ALERTS=1
      [toolbox-cli]
    • Send an email when the alert happens.
      [toolbox-cli] set settings EMAIL_ALERTS=1
      [toolbox-cli]
  3. Restart the toolbox daemon.
    See Enable or Disable the Toolbox CLI Daemon.
  4. Replace the HCA.
    Follow the instructions for your HCA.
    Upon powering on the new HCA, entries are written to the log. For example:
    [15/Sep/2015 20:03:41] "INFO Node Description change detected on active HCA: scao04adm02 mlx4_0 -> scao04adm02 S 0.0.0.0,0.0.0.0 HCA-1"
    [15/Sep/2015 20:03:41] "INFO Toolbox alert!"
    [15/Sep/2015 20:03:43] "INFO Alert:
    New GUID in Port Switch
    Date:           15/Sep/2015 20:03:41
    Switch:         scao04sw-ibb0
    Port:           10
    First seen:     15/Sep/2015 20:00:12
    Discovered:     15/Sep/2015 20:00:12
    Last seen:      15/Sep/2015 20:03:40
    New caguid:     0x000000001234abcd
    New port guid:  0x000000001234abcf
    Type:           HCA
    Description:    scao04adm02 S 0.0.0.0,0.0.0.0 HCA-1
    Old caguid:     0x0002c90300a3ca60
    Old port guid:  0x0002c90300a3ca62
    Switch:         scao04sw-iba0
    Port:           10
    Last seen:      15/Sep/2015 20:03:39
    New port guid:  0x000000001234abce
    Type:           HCA
    Old port guid:  0x0002c90300a3ca61
    If configured, an email is sent. For example:
    Send Mail ['root@localhost.com']: Done"
    [15/Sep/2015 20:03:46] "INFO Replacing GUID 0x0002c90300a3ca61 --> 0x000000001234abce"
    [15/Sep/2015 20:03:49] "INFO Replacing GUID 0x0002c90300a3ca62 --> 0x000000001234abcf"
Related Information
