[toolbox-cli] set partition name=name|pkey=P_Key add port portguid=GUID [-m=full|limited|both]
where:
name is the partition name.
P_Key is the partition key.
GUID is the port GUID.
For example, to add a port with GUID 0x0002c903000891ac and limited membership to the partition with P_Key 1122, type:
[toolbox-cli] set partition pkey=1122 add port portguid=0x002c903000891ac -m=limited [toolbox-cli]
[toolbox-cli] show partition pkey=1122 ports NAME : test4 PKEY : 1122 FLAGS : ipoib, rate=4, sl=5 GUID MEMBER ------------------ ------- 0x0002c903000891ac limited 0x0002c90300089240 [toolbox-cli]
