where:
name is the host name of the switch.
M_Key is the 16-hex digit management key. For example 0xa000000000000001.
peer_IP_address is the IP address of the peer switch.
peer_hostname is the host name of the peer switch to receive or having the configuration.
local_IP_address is the IP address of the management controller on the switch.
sm_name is the previous host name of the Subnet Manager on the switch.
filename is the file name of the backup configuration.
URL is the URL of the remote server backup file location.
fabric_name is the name of the fabric to which the switch will belong.
rack_name is the name of the rack to which the switch will belong.
sm_state is the state of the Subnet Manger after restoration, either enabled or disabled.
