Go to main content
Sun Network QDR InfiniBand Gateway Switch Documentation Supplement for Firmware Version 2.2
Exit Print View
Updated: September 2016
Modify a Port of a Partition (Toolbox CLI)
  1. In the Toolbox CLI, modify a port to the partition.
    [toolbox-cli] set partition name=name|pkey=P_Key set port portguid=GUID [-m=full|limited|both]
    where:
    • name is the partition name.
    • P_Key is the partition key.
    • GUID is the port GUID.
    For example, to set the port with GUID 0x0002c903000891ac in the partition with P_Key 1122 to full membership, type:
    [toolbox-cli] set partition pkey=1122 set port portguid=0x0002c903000891ac -m=full
    [toolbox-cli]
  2. Verify that the membership was modified.
    [toolbox-cli] show partition pkey=1122 ports
    PKEY    : 1122
    FLAGS   : ipoib, rate=4, sl=5
    GUID                   MEMBER
    0x0002c903000891ac     full
    0x0002c90300089240
    [toolbox-cli]
Related Information
