You can use this procedure when replacing an HCA within a server, or exchanging a server and requiring the same fabric configuration as previously.
[toolbox-cli] show partition all ports NAME : SUN_DCS PKEY : 0001 FLAGS : ipoib GUID MEMBER ------------ ------ ALL_SWITCHES full NAME : nm2-box1 PKEY : 3342 FLAGS : ipoib, defmember=full GUID MEMBER ------------------ ------ 0x0002c9030008e137 full 0x00212800013ecea0 both NAME : Default PKEY : 7fff FLAGS : ipoib GUID MEMBER ------------------ ------- ALL_CAS full ALL_SWITCHES full 0x0010e00001631b01 limited [toolbox-cli]
Follow the instructions for your HCA.
[toolbox-cli] manage partition replace-guid current=old_GUID new=new_GUID
where:
old_GUID is the previous HCA port GUID.
new_GUID is the new HCA port GUID.
For example, to replace GUID 0x00212800013ecea0 with 0x111111111111111111, type:
[toolbox-cli] manage partition replace-port-guid current=0x00212800013ecea0 new=0x111111111111111111 [toolbox-cli]
[toolbox-cli] show partition all ports NAME : SUN_DCS PKEY : 0001 FLAGS : ipoib GUID MEMBER ------------ ------ ALL_SWITCHES full NAME : nm2-box1 PKEY : 3342 FLAGS : ipoib, defmember=full GUID MEMBER -------------------- ------ 0x0002c9030008e137 full 0x111111111111111111 both NAME : Default PKEY : 7fff FLAGS : ipoib GUID MEMBER ------------------ ------- ALL_CAS full ALL_SWITCHES full 0x0010e00001631b01 limited [toolbox-cli]
