Macro Integration Point
The macro integration point accepts the following POST request payload:
http://[hostName]:[portNumber]/[api-context-root]/<context-root>/macros
"parameters": [
"name": "",
"value": "" // multivalued parameters hold a comma separated list of values
"name": "",
"value": ""
"macroDefinitionCode": ""
"requestContext": "{ "id": // Mandatory }" provided as string representation; Resembles generic api GET response structure
or is an array, list of records in context of macro execution given by thier id
"requestContextList": [
"id": // Mandatory
"id":
Context for group client (nonlist) example.
"requestContext": {
"id": "" //mandatory
"code": "",
"displayName": "",
"groupAccountList": [
"id": "26551"
| The macro request context element must specify the object id. This is the subject id for macro history for non-list-based macros. |
OIG Integration
The system starts OIG integration as specified by the property ohi.macro.{0}.endpoint.
The system sends the macro request as-is, along with the details of the macro resource (rel-link subject) as the payload for OIG integration.
To invoke OIG integration, it uses credentials and authentication methods for credentialKey OIG_INTEGRATION_{macrocode}.
Sample Request of Payload created by the system to start the OIG integration:
"parameters":[{
"name":"",
"value":"" // multivalued parameters hold a comma separated list of values
"name":"",
"value":""
"links": [{
"href" : "refers to macro history",
"rel" : "subject",
"httpMethod" : "GET"
"requestContext":
"id"
"code": "",
"displayName": "",
"groupAccountList": [{
"id": "26551" }]}
The response for such a macro contains an operator link with a reference to the underlying exchange.
Sample Response of Success
201: Created
"links":[{
"href" : "Exchange URI",
"rel" : "operator",
"href" : "refers to macro history,
"rel" : "monitor",
If the integration fails to start, one or more error messages are returned as given by the integration
Response
The integration point may return HTTP status codes as defined in Response Messages. If an error occurs, the appropriate HTTP status code (along with a payload containing the error details) is returned.
The following operation-specific errors can occur:
| Code | Severity | Message Text |
OHI-IP-MRDF-001 |
Fatal |
Macro definition code is unknown. |
OHI-IP-MRDF-002 |
Fatal |
Request context could not be parsed. |
OHI-IP-MRDF-003 |
Fatal |
Request context or request context list with a valid id element to identify the context object(s) must be specified. |
OHI-IP-MRDF-004 |
Fatal |
Either request context or request context list must be specified and not both. |
OHI-IP-MRDF-005 |
Fatal |
Request context list must be specified if the macro definition indicates it is for a list. |
