Skip Navigation Links | |
Exit Print View | |
Sun Network QDR InfiniBand Gateway Switch HTML Document Collection for Firmware Version 2.0 |
Network Management Connector and Pins
Preparing to Install the Gateway
Assemble the Ethernet Splitter Data Cables
Install the Gateway in the Rack
Understanding Routing Through the Gateway
Configuring the Fabric Director Node List
Partitioning the InfiniBand Fabric
Administering Gateway Resources
Installing Gateway Supportive Software (Linux)
Creating VNICs Under Gateway Manual Mode (Linux)
Creating VNICs Under Host Manual Mode (Linux)
Creating Virtual IO Adapters (Oracle Solaris)
Controlling Gateway Ports and Parameters
Understanding Oracle ILOM on the Gateway
Upgrading the Gateway Firmware Through Oracle ILOM (CLI)
Upgrade the Gateway Firmware (Web)
Display Gateway Status LED States (IPMI)
Remove the Gateway From the Rack
Dumps target information to a remote location.
dump [-destination URI][target]
where:
URI is the uniform resource indicator.
target is the target and path to act upon.
This Oracle ILOM command transfers target information to a remote location specified by the URI. If no target is specified, the current target is affected. Your user must have administrator (a) privileges to use this command. The -destination option specifies the location. If the -destination option is not used, then the information is transferred to stdout.
This example shows how to transfer the /SP/services/snmp/mibs target information to the ilom-mibs.zip file on the host with IP address 123.45.67.89 using the FTP protocol with the dump command.
-> dump -destination ftp://root:changeme@123.45.67.89/tftpboot/ilom-mibs.zip /SP/services/snmp/mibs ->
