Skip Navigation Links
Exit Print View
Sun Network QDR InfiniBand Gateway Switch HTML Document Collection for Firmware Version 2.0
search filter icon
search icon
Document Information
Using This Documentation
Product Notes
Related Documentation
Support and Accessibility
Understanding the Gateway
Gateway Overview
Physical Specifications
Environmental Requirements
Acoustic Noise Emissions
Electrical Specifications
Network Management Connector and Pins
Data QSFP Connector and Pins
Understanding Cabling
Routing Service Cables
Understanding Data Cabling
Preparing to Install the Gateway
Installation Preparation
Installation Responsibilities
Installation Sequence
Assemble the Ethernet Splitter Data Cables
Route the Data Cables
Installing the Gateway
Install the Gateway in the Rack
Powering On the Gateway
Connecting Data cables
Troubleshooting the Gateway
Gateway Hardware Problems
InfiniBand Fabric Problems
Identifying LEDs
Understanding Routing Through the Gateway
Switch GUIDs Overview
Configuration Overview
Hardware Command Overview
InfiniBand Command Overview
ILOM Command Overview
Administering the Chassis
Monitoring the Chassis
Controlling the Chassis
Monitoring the I4 Switch Chip
Monitoring the Subnet Manager
Configuring the Fabric Director Node List
Partitioning the InfiniBand Fabric
Administering Gateway Resources
Installing Gateway Supportive Software (Linux)
Creating VNICs Under Gateway Manual Mode (Linux)
Creating VNICs Under Host Manual Mode (Linux)
Creating Virtual IO Adapters (Oracle Solaris)
Monitoring Gateway Resources
Controlling LAGs
Controlling VLANs and VNICs
Controlling Gateway Ports and Parameters
Remote Management
Understanding Oracle ILOM on the Gateway
Oracle ILOM Overview
Supported Features
CLI Overview
Upgrading the Gateway Firmware Through Oracle ILOM (CLI)
Web Interface Overview
Upgrade the Gateway Firmware (Web)
Using the Fabric Monitor
Access the Fabric Monitor
Fabric Monitor Features
Control Panel Function
SNMP Overview
Understanding SNMP Commands
Administering Hardware (IPMI)
ipmitool Overview
Display Gateway Status LED States (IPMI)
Enable the Locator LED (IPMI)
cd Command
create Command
delete Command
dump Command
exit Command (ILOM)
help Command (ILOM)
load Command
reset Command
set Command
show Command
version Command (ILOM)
Replaceable Components
Suggested Tools for Service
Servicing Power Supplies
Inspecting a Power Supply
Power Off a Power Supply
Remove a Power Supply
Install a Power Supply
Power On a Power Supply
Servicing Fans
Inspecting a Fan
Remove a Fan
Install a Fan
Servicing Data Cables
Inspecting the Data Cables
Remove a Data Cable
Install a Data Cable
Servicing the Battery
Remove the Gateway From the Rack
Replace the Battery
addlagport Command
allowhostconfig Command
checkboot Command
checkpower Command
checktopomax Command
checkvoltages Command
connector Command
createlag Command
createvlan Command
createvnic Command
dcsport Command
deletelag Command
deletevlan Command
deletevnic Command
dellagport Command
disablecablelog Command
disablegwport Command
disablelagmode Command
disablelinklog Command
disablesm Command
disableswitchport Command
disablevnic Command
disallowhostconfig Command
enablecablelog Command
enablegwport Command
enablelagmode Command
enablelinklog Command
enablesm Command
enableswitchport Command
enablevnic Command
env_test Command
exit Command (Hardware)
fdconfig Command
fwverify Command
generatetopology Command
getfanspeed Command
getmaster Command
getportcounters Command
getportstatus Command
help Command (Hardware)
listlinkup Command
matchtopology Command
setcontrolledhandover Command
setdefaultgwdiscpkey Command
setgwethport Command
setgwinstance Command
setgwsl Command
setgwsystemname Command
setmsmlocationmonitor Command
setsmmkey Command
setsmpriority Command
setsubnetprefix Command
showfruinfo Command
showgwconfig Command
showgwports Command
showlag Command
showpsufru Command
showsmlog Command
showtemps Command
showtopology Command
showunhealthy Command
showvlan Command
showvnics Command
smconfigtest Command
smnodes Command
smpartition Command
version Command (Hardware)
ibdiagnet Command
ibhosts Command
ibnetdiscover Command
ibnetstatus Command
ibnodes Command
ibportstate Command
ibroute Command
ibrouters Command
ibstat Command
ibswitches Command
ibtracert Command
perfquery Command
saquery Command
smpquery Command
Understanding SNMP MIB OIDs
OID Tables Overview
Understanding the ENTITY-MIB MIB OIDs
Creates topology file.
generatetopology topofile|[-h]
where topofile is the filename and path to the topology file.
This hardware command creates a topology file of the InfiniBand fabric. This file is not compatible with the topology file created by the ibnetdiscover command. The generatetopology command is used with the matchtopology and showtopology commands to determine changes in the InfiniBand fabric. The -h option provides help.
The generatetopology command is available from the /SYS/Fabric_Mgmt Linux shell target of the Oracle ILOM CLI interface.
This example shows how to create a topology file called Topo.conf with the generatetopology command.
# generatetopology AUG22.topo
It will take some time to generate a topology file. Please wait!
topo.conf file is created. Will now start generating the topo file
Wrote Topology file: AUG22.topo
This is a portion of a topology file created by the generatetopology command.
Note - Your topology file will differ.
SUNIBQDRGW mnm34-98 Bridge 0
     BX1/P1 -4x-10G-> I4_GENERIC mnm34-98 P4
         -4x-10G-> I4_GENERIC mnm34-98 P3
     BX3/P1 -4x-10G-> I4_GENERIC mnm34-98 P2
         -4x-10G-> I4_GENERIC mnm34-98 P1
DEV26428_02P mnm34-55_HCA-1
     P1 -4x-10G-> SUNIBQDRGW mnm34-97 C-7A
     P2 -4x-10G-> I4_GENERIC mnm34-98 P33
     A-SW/P2 -4x-10G-> SUNIBQDRGW mnm34-97 BX3/P1
     A-SW/P4 -4x-10G-> SUNIBQDRGW mnm34-97 BX1/P1
     C-0B -4x-10G-> I4_GENERIC mnm34-98 P21
     C-0A -4x-10G-> I4_GENERIC mnm34-98 P20
     C-1B -4x-10G-> I4_GENERIC mnm34-98 P19
     C-1A -4x-10G-> I4_GENERIC mnm34-98 P22
     C-2B -4x-10G-> I4_GENERIC mnm34-98 P24
     C-2A -4x-10G-> I4_GENERIC mnm34-98 P23
DEV26428_02P mnm34-60_HCA-1
     P1 -4x-10G-> SUNIBQDRGW mnm34-97 C-8A
     P2 -4x-10G-> I4_GENERIC mnm34-98 P31
# Created from mnm34-98 at Thu Aug 19 13:32:25 PDT 2010
Related Information
