Skip Navigation Links | |
Exit Print View | |
Sun Network QDR InfiniBand Gateway Switch HTML Document Collection for Firmware Version 2.0 |
Network Management Connector and Pins
Preparing to Install the Gateway
Assemble the Ethernet Splitter Data Cables
Install the Gateway in the Rack
Understanding Routing Through the Gateway
Configuring the Fabric Director Node List
Partitioning the InfiniBand Fabric
Administering Gateway Resources
Installing Gateway Supportive Software (Linux)
Creating VNICs Under Gateway Manual Mode (Linux)
Creating VNICs Under Host Manual Mode (Linux)
Creating Virtual IO Adapters (Oracle Solaris)
Controlling Gateway Ports and Parameters
Understanding Oracle ILOM on the Gateway
Upgrading the Gateway Firmware Through Oracle ILOM (CLI)
Upgrade the Gateway Firmware (Web)
Display Gateway Status LED States (IPMI)
Remove the Gateway From the Rack
Sets the system name.
setgwsystemname systemname|--list|--clear [-h]
where systemname is the BridgeX manager’s system name.
This hardware command displays or sets the system name as recognized by the BridgeX manager. By default, the host name is the system name. The system name cannot be more than 19 characters long, otherwise it is truncated to 19 characters.
The setgwsystemname command is available from the /SYS/Gateway_Mgmt and /SYS/Fabric_Mgmt Linux shell targets of the Oracle ILOM CLI interface.
This table describes the options to the setgwsystemname command and their purposes.
Note - If you want to use a double-dash (--) in the system name, you must delimit the string with escape characters. See the example.
This example shows how to set the system name recognized by the BridgeX manager to --myname using the setgwsystemname command.
# setgwsystemname “\”--myname\”” Stopping Bridge Manager.. [ OK ] Starting Bridge Manager. [ OK ] # setgwsystemname --list BXM system name set to --myname #
