Skip Navigation Links
Exit Print View
Sun Network QDR InfiniBand Gateway Switch HTML Document Collection for Firmware Version 2.0
search filter icon
search icon
Document Information
Using This Documentation
Product Notes
Related Documentation
Feedback
Support and Accessibility
Installation
Understanding the Gateway
Gateway Overview
Physical Specifications
Environmental Requirements
Acoustic Noise Emissions
Electrical Specifications
Network Management Connector and Pins
Data QSFP Connector and Pins
Understanding Cabling
Routing Service Cables
Understanding Data Cabling
Preparing to Install the Gateway
Installation Preparation
Installation Responsibilities
Installation Sequence
Assemble the Ethernet Splitter Data Cables
Route the Data Cables
Installing the Gateway
Install the Gateway in the Rack
Powering On the Gateway
Connecting Data cables
Administration
Troubleshooting the Gateway
Gateway Hardware Problems
InfiniBand Fabric Problems
Identifying LEDs
Understanding Routing Through the Gateway
Switch GUIDs Overview
Configuration Overview
Hardware Command Overview
InfiniBand Command Overview
ILOM Command Overview
Administering the Chassis
Monitoring the Chassis
Controlling the Chassis
Monitoring the I4 Switch Chip
Monitoring the Subnet Manager
Configuring the Fabric Director Node List
Partitioning the InfiniBand Fabric
Administering Gateway Resources
Installing Gateway Supportive Software (Linux)
Creating VNICs Under Gateway Manual Mode (Linux)
Creating VNICs Under Host Manual Mode (Linux)
Creating Virtual IO Adapters (Oracle Solaris)
Monitoring Gateway Resources
Controlling LAGs
Controlling VLANs and VNICs
Controlling Gateway Ports and Parameters
Remote Management
Understanding Oracle ILOM on the Gateway
Oracle ILOM Overview
Supported Features
CLI Overview
Upgrading the Gateway Firmware Through Oracle ILOM (CLI)
Web Interface Overview
Performing Daily Tasks (Web)
Display the Date (Web)
Display the Gateway Status LEDs States (Web)
Display the Aggregate Sensors State (Web)
Display Power Supply Status (Web)
Display Board-Level Voltages (Web)
Display Internal Temperatures (Web)
Display Fan Status (Web)
Display the Oracle ILOM Sessions (Web)
Display the Oracle ILOM Event Log (Web)
Checking the Status of Services (Web)
Display the HTTP Service Status (Web)
Display the HTTPS Service Status (Web)
Display the SSL Certificates (Web)
Display the SNMP Service Status (Web)
Display the SNMP Service User Accounts (Web)
Display the SNMP Service Communities (Web)
Display the IPMI Service Status (Web)
Display the DNS Client Status (Web)
Display the SMTP Client Status (Web)
Display the Network Time Protocol Servers (Web)
Verifying Other Aspects With Oracle ILOM (Web)
Display the Alert Properties (Web)
Display the Oracle ILOM User Accounts (Web)
Display the Remote Log Hosts (Web)
Display the Network Management Configuration (Web)
Display the CLI Session Timeout (Web)
Display System Component FRU ID (Web)
Display the Firmware Version (Web)
Display the Oracle ILOM Version (Web)
Display System Identification Properties (Web)
Performing General Tasks on Oracle ILOM Targets (Web)
Restart the Management Controller (Web)
Set the Date and Time (Web)
Set the Time Zone (Web)
Enable the Locator LED (Web)
Disable the Locator LED (Web)
Clear the Oracle ILOM Event Log (Web)
Set the Remote Log Hosts (Web)
Configure the DNS Client (Web)
Configure the SMTP Client (Web)
Back Up the Configuration (Web)
Restore the Configuration (Web)
Create a Snapshot of the Gateway State (Web)
Snapshot Dataset Information (Web)
Set the Network Management Parameters (Web)
Set the System Identification Properties (Web)
Performing Oracle ILOM User Tasks (Web)
Add an Oracle ILOM User Account (Web)
Change an Oracle ILOM User’s Password and or Role (Web)
Delete an Oracle ILOM User Account (Web)
Managing HTTP Services (Web)
Enable the HTTP Service (Web)
Disable the HTTP Service (Web)
Managing HTTPS Services (Web)
Enable the HTTPS Service (Web)
Install a Custom SSL Certificate (Web)
Remove the Custom SSL Certificate (Web)
Disable the HTTPS Service (Web)
Managing SNMP Services (Web)
Enable the SNMP Service (Web)
Configure the SNMP Service (Web)
Add SNMP Service User Accounts (Web)
Modify SNMP Service User Accounts (Web)
Delete SNMP Service User Accounts (Web)
Add SNMP Service Communities (Web)
Modify SNMP Service Communities (Web)
Delete SNMP Service Communities (Web)
Download SNMP Service MIBs (Web)
Disable the SNMP Service (Web)
Managing IPMI Services (Web)
Enable the IPMI Service (Web)
Disable the IPMI Service (Web)
Managing Other Aspects With Oracle ILOM (Web)
Enable Alerts to Send SNMP Traps (Web)
Enable Alerts to Send PETs (Web)
Enable Alerts to Send Email Alerts (Web)
Disable Alerts (Web)
Set the CLI Session Timeout (Web)
Upgrade the Gateway Firmware (Web)
Using the Fabric Monitor
Access the Fabric Monitor
Fabric Monitor Features
Control Panel Function
SNMP Overview
Understanding SNMP Commands
Administering Hardware (IPMI)
ipmitool Overview
Display Gateway Status LED States (IPMI)
Enable the Locator LED (IPMI)
cd Command
create Command
delete Command
dump Command
exit Command (ILOM)
help Command (ILOM)
load Command
reset Command
set Command
show Command
version Command (ILOM)
Service
Replaceable Components
Suggested Tools for Service
Servicing Power Supplies
Inspecting a Power Supply
Power Off a Power Supply
Remove a Power Supply
Install a Power Supply
Power On a Power Supply
Servicing Fans
Inspecting a Fan
Remove a Fan
Install a Fan
Servicing Data Cables
Inspecting the Data Cables
Remove a Data Cable
Install a Data Cable
Servicing the Battery
Remove the Gateway From the Rack
Replace the Battery
Reference
addlagport Command
allowhostconfig Command
checkboot Command
checkpower Command
checktopomax Command
checkvoltages Command
connector Command
createlag Command
createvlan Command
createvnic Command
dcsport Command
deletelag Command
deletevlan Command
deletevnic Command
dellagport Command
disablecablelog Command
disablegwport Command
disablelagmode Command
disablelinklog Command
disablesm Command
disableswitchport Command
disablevnic Command
disallowhostconfig Command
enablecablelog Command
enablegwport Command
enablelagmode Command
enablelinklog Command
enablesm Command
enableswitchport Command
enablevnic Command
env_test Command
exit Command (Hardware)
fdconfig Command
fwverify Command
generatetopology Command
getfanspeed Command
getmaster Command
getportcounters Command
getportstatus Command
help Command (Hardware)
listlinkup Command
matchtopology Command
setcontrolledhandover Command
setdefaultgwdiscpkey Command
setgwethport Command
setgwinstance Command
setgwsl Command
setgwsystemname Command
setmsmlocationmonitor Command
setsmmkey Command
setsmpriority Command
setsubnetprefix Command
showfruinfo Command
showgwconfig Command
showgwports Command
showlag Command
showpsufru Command
showsmlog Command
showtemps Command
showtopology Command
showunhealthy Command
showvlan Command
showvnics Command
smconfigtest Command
smnodes Command
smpartition Command
version Command (Hardware)
ibdiagnet Command
ibhosts Command
ibnetdiscover Command
ibnetstatus Command
ibnodes Command
ibportstate Command
ibroute Command
ibrouters Command
ibstat Command
ibswitches Command
ibtracert Command
perfquery Command
saquery Command
smpquery Command
Understanding SNMP MIB OIDs
OID Tables Overview
Understanding the ENTITY-MIB MIB OIDs
Index
Note - If you are going to downgrade the firmware to a version earlier than 2.0, you must remove user partitions and depopulate the Subnet Manager nodes list. See Gateway Administration, removing partitions for firmware downgrade.
  1. Acquire the firmware package.
    See Acquire the Gateway Firmware Package (CLI).
  2. Open an SSH session and connect to the management controller by specifying the controller’s host name.
    For example:
    % ssh -l root nm2name
    root@nm2name’s password: password
    where nm2name is the host name of the management controller. Initially, the password is changeme.
  3. If the Subnet Manager is running on the management controller, disable it with the disablesm command.
    # disablesm
    Stopping partitiond daemon.                                [  OK  ]
    Stopping IB Subnet Manager..                               [  OK  ]
  4. Verify that there is at least 150 MB available in the /tmp directory.
    # df -h /tmp
    Filesystem            Size  Used Avail Use% Mounted on
    tmpfs                 250M  240K 249M 1% /tmp
    In this example, there are 249 MB available. If not enough space is available, you must delete files from the /tmp directory.
  5. Verify that there is at least 1 MB available in the /config directory.
    # df -h /config
    /dev/hda2              16M  3.6M   11M  25% /config
    In this example, there are 11 MB available. If not enough space is available, you must delete files from the /config directory.
  6. Verify that there is at least 1 MB available in the /var/log directory.
    # df -h /var/log
    /dev/hda3              16M  3.6M   11M  25% /var/log
    In this example, there are 11 MB available. If not enough space is available, you must delete files from the /var/log directory.
  7. Verify that there is at least 150 MB free memory available.
    # free -m
                     total       used       free     shared    buffers     cached
    Mem:           498        104        393          0         12         47
    -/+ buffers/cache:         45        453
    Swap:            0          0          0
    In the -/+ buffers/cache: row of the free column, there should be at least 150 MB free memory. In this example, there are 453 MB available. If not enough memory is available, you must exit nonessential applications that are running.
  8. Access the Oracle ILOM web interface.
    See Access Oracle ILOM From the Web Interface.
  9. Click the Maintenance tab.
  10. Click the Firmware Upgrade subtab.
    The Firmware Upgrade window opens.
  11. Click Enter Upgrade Mode.
    A dialog box opens and asks you to confirm.
  12. Click OK.
    The Firmware Upgrade window changes to Upgrade mode and now accepts a URL and file name of the gateway firmware package.
    Note - For the specified URL, only the FTP or HTTP protocols are supported.
  13. Click Upload.
    Oracle ILOM transfers the gateway firmware package to the management controller. Oracle ILOM verifies the package integrity and displays the current versions of the firmware and versions in the package.
  14. Click Start Upgrade.
  15. Click OK.
    The upgrade begins and the status of the upgrade is reported.
    When the upgrade process ends, a log and summary report are displayed.
  16. Click OK.
    A final status is displayed, the upgrade either:
    • Succeeded
    • Partially succeeded
    • Failed
  17. Reboot the gateway to enable the new firmware.
    See Gateway Administration, restarting the entire gateway.
    Note - The restart process takes between 4 to 5 minutes to complete.
    You can monitor the update progress through:
    • web browser – http://gateway_name
    • CLI – telnet gateway_name 1234
    where gateway_name is the host name or IP address of the management controller.
    Note - The Oracle ILOM stack requires at least 2 minutes to become operational after a reboot.
  18. If the Subnet Manager was previously disabled, open an SSH session, connect to the management controller, and enable the Subnet Manager.
    % ssh -l root gateway_name
    root@gateway_name’s password: password
    # enablesm
    Starting IB Subnet Manager.                                [  OK  ]
    Starting partitiond daemon.                                [  OK  ]
    # exit
  19. Access the Oracle ILOM web interface.
  20. Verify the success of the firmware update.
    See Display the Firmware Version (Web).
  21. Verify the firmware integrity.
    See Verify Firmware Integrity (CLI).
Related Information
