Skip Navigation Links | |
Exit Print View | |
Sun Network QDR InfiniBand Gateway Switch HTML Document Collection for Firmware Version 2.0 |
Network Management Connector and Pins
Preparing to Install the Gateway
Assemble the Ethernet Splitter Data Cables
Install the Gateway in the Rack
Understanding Routing Through the Gateway
Configuring the Fabric Director Node List
Partitioning the InfiniBand Fabric
Administering Gateway Resources
Installing Gateway Supportive Software (Linux)
Creating VNICs Under Gateway Manual Mode (Linux)
Creating VNICs Under Host Manual Mode (Linux)
Creating Virtual IO Adapters (Oracle Solaris)
Controlling Gateway Ports and Parameters
Understanding Oracle ILOM on the Gateway
Upgrading the Gateway Firmware Through Oracle ILOM (CLI)
Upgrade the Gateway Firmware (Web)
Display Gateway Status LED States (IPMI)
Remove the Gateway From the Rack
Enables LAG mode.
enablelagmode [-h]
This hardware command enables LAG mode. By default, LAG mode is disabled. LAGs are a means of effectively increasing the bandwidth of an Ethernet network by grouping ports. To successfully run the enablelagmode command, the BXOFED software used by the gateway and hosts must be version 1.3.9 or later. The [-h] option to the enablelagmode command provides help.
Note - LAG mode must be enabled on all InfiniBand gateways in the fabric before LAGs are created.
The enablelagmode command is available from the /SYS/Gateway_Mgmt and /SYS/Fabric_Mgmt Linux shell targets of the Oracle ILOM CLI interface.
This example shows how to enable LAG mode with the enablelagmode command.
# enablelagmode VNICs for host nodes with EoIB driver version that do not support LAG will go down if LAG mode is enabled. Do you still want to enable LAG(y/n)?y Stopping Bridge Manager.. [ OK ] Starting Bridge Manager. [ OK ] #
