Skip Navigation Links
Exit Print View
Sun Network QDR InfiniBand Gateway Switch HTML Document Collection for Firmware Version 2.0
search filter icon
search icon
Document Information
Using This Documentation
Product Notes
Related Documentation
Feedback
Support and Accessibility
Installation
Understanding the Gateway
Gateway Overview
Physical Specifications
Environmental Requirements
Acoustic Noise Emissions
Electrical Specifications
Network Management Connector and Pins
Data QSFP Connector and Pins
Understanding Cabling
Routing Service Cables
Understanding Data Cabling
Preparing to Install the Gateway
Installation Preparation
Installation Responsibilities
Installation Sequence
Assemble the Ethernet Splitter Data Cables
Route the Data Cables
Installing the Gateway
Install the Gateway in the Rack
Powering On the Gateway
Connecting Data cables
Administration
Troubleshooting the Gateway
Gateway Hardware Problems
InfiniBand Fabric Problems
Identifying LEDs
Understanding Routing Through the Gateway
Switch GUIDs Overview
Configuration Overview
Hardware Command Overview
InfiniBand Command Overview
ILOM Command Overview
Administering the Chassis
Monitoring the Chassis
Controlling the Chassis
Monitoring the I4 Switch Chip
Monitoring the Subnet Manager
Configuring the Fabric Director Node List
Partitioning the InfiniBand Fabric
Administering Gateway Resources
Installing Gateway Supportive Software (Linux)
Creating VNICs Under Gateway Manual Mode (Linux)
Creating VNICs Under Host Manual Mode (Linux)
Creating Virtual IO Adapters (Oracle Solaris)
Monitoring Gateway Resources
Controlling LAGs
Controlling VLANs and VNICs
Controlling Gateway Ports and Parameters
Remote Management
Understanding Oracle ILOM on the Gateway
Oracle ILOM Overview
Supported Features
CLI Overview
Upgrading the Gateway Firmware Through Oracle ILOM (CLI)
Web Interface Overview
Upgrade the Gateway Firmware (Web)
Using the Fabric Monitor
Access the Fabric Monitor
Fabric Monitor Features
Control Panel Function
SNMP Overview
Understanding SNMP Commands
Administering Hardware (IPMI)
ipmitool Overview
Display Gateway Status LED States (IPMI)
Enable the Locator LED (IPMI)
cd Command
create Command
delete Command
dump Command
exit Command (ILOM)
help Command (ILOM)
load Command
reset Command
set Command
show Command
version Command (ILOM)
Service
Replaceable Components
Suggested Tools for Service
Servicing Power Supplies
Inspecting a Power Supply
Power Off a Power Supply
Remove a Power Supply
Install a Power Supply
Power On a Power Supply
Servicing Fans
Inspecting a Fan
Remove a Fan
Install a Fan
Servicing Data Cables
Inspecting the Data Cables
Remove a Data Cable
Install a Data Cable
Servicing the Battery
Remove the Gateway From the Rack
Replace the Battery
Reference
addlagport Command
allowhostconfig Command
checkboot Command
checkpower Command
checktopomax Command
checkvoltages Command
connector Command
createlag Command
createvlan Command
createvnic Command
dcsport Command
deletelag Command
deletevlan Command
deletevnic Command
dellagport Command
disablecablelog Command
disablegwport Command
disablelagmode Command
disablelinklog Command
disablesm Command
disableswitchport Command
disablevnic Command
disallowhostconfig Command
enablecablelog Command
enablegwport Command
enablelagmode Command
enablelinklog Command
enablesm Command
enableswitchport Command
enablevnic Command
env_test Command
exit Command (Hardware)
fdconfig Command
fwverify Command
generatetopology Command
getfanspeed Command
getmaster Command
getportcounters Command
getportstatus Command
help Command (Hardware)
listlinkup Command
matchtopology Command
setcontrolledhandover Command
setdefaultgwdiscpkey Command
setgwethport Command
setgwinstance Command
setgwsl Command
setgwsystemname Command
setmsmlocationmonitor Command
setsmmkey Command
setsmpriority Command
setsubnetprefix Command
showfruinfo Command
showgwconfig Command
showgwports Command
showlag Command
showpsufru Command
showsmlog Command
showtemps Command
showtopology Command
showunhealthy Command
showvlan Command
showvnics Command
smconfigtest Command
smnodes Command
smpartition Command
version Command (Hardware)
ibdiagnet Command
ibhosts Command
ibnetdiscover Command
ibnetstatus Command
ibnodes Command
ibportstate Command
ibroute Command
ibrouters Command
ibstat Command
ibswitches Command
ibtracert Command
perfquery Command
saquery Command
smpquery Command
Understanding SNMP MIB OIDs
OID Tables Overview
Understanding the ENTITY-MIB MIB OIDs
Index
The preferred method of accessing the Linux shell is through the /SYS/Switch_Diag, /SYS/Gateway_Mgmt, and /SYS/Fabric_Mgmt Linux shell targets of the Oracle ILOM CLI interface.
Using the show command on the /SYS/Switch_Diag target opens a restricted Linux shell that enables the ilom-admin user, ilom-operator user, and users with similar permissions to run diagnostic commands.
Using the show command on the /SYS/Gateway_Mgmt target opens a different restricted Linux shell that enables the ilom-admin user and users with similar permissions to run both diagnostic and gateway management commands.
Using the show command on the /SYS/Fabric_Mgmt target opens still an other restricted Linux shell that enables the ilom-admin user and users with similar permissions to run diagnostic, gateway, and fabric management commands.
Note - The ilom-operator user cannot access the Linux shell from either the /SYS/Gateway_Mgmt or /SYS/Fabric_Mgmt target.
This table lists the hardware commands and their availability from the respective Linux shell targets. Typing the help all command from within the restricted shells lists the commands available to that shell.
Note - Hardware commands that are not listed are unavailable from the /SYS/Switch_Diag, /SYS/Gateway_Mgmt, or /SYS/Fabric_Mgmt targets.
Command
/SYS/Switch_Diag
/SYS/Gateway_Mgmt
/SYS/Fabric_Mgmt
addlagport
Available
Available
allowhostconfig
Available
Available
checkboot
Available
Available
Available
checkpower
Available
Available
Available
checktopomax
Available
checkvoltages
Available
Available
Available
connector
Available
Available
Available
createlag
Available
Available
createvlan
Available
Available
createvnic
Available
Available
dcsport
Available
Available
Available
deletelag
Available
Available
deletevlan
Available
Available
deletevnic
Available
Available
dellagport
Available
Available
disablecablelog
Available
disablegwport
Available
Available
disablelagmode
Available
Available
disablelinklog
Available
disablesm
Available
disableswitchport
Available
disablevnic
Available
Available
disallowhostconfig
Available
Available
enablecablelog
Available
enablegwport
Available
Available
enablelagmode
Available
Available
enablelinklog
Available
enablesm
Available
enableswitchport
Available
enablevnic
Available
Available
env_test
Available
Available
Available
exit
Available
Available
Available
fdconfig
Available
fwverify
Available
Available
Available
generatetopology
Available
getfanspeed
Available
Available
Available
getmaster
Available
Available
Available
getportcounters
Available
Available
Available
getportstatus
Available
Available
Available
help
Available
Available
Available
listlinkup
Available
Available
Available
matchtopology
Available
Available
Available
Available
setgwethport
Available
Available
setgwinstance
Available
Available
setgwsl
Available
Available
setgwsystemname
Available
Available
Available
setsmmkey
Available
setsmpriority
Available
setsubnetprefix
Available
showfruinfo
Available
Available
Available
showgwconfig
Available
Available
showgwports
Available
Available
showlag
Available
Available
showpsufru
Available
Available
Available
showsmlog
Available
Available
Available
showtemps
Available
Available
Available
showtopology
Available
Available
Available
showunhealthy
Available
Available
Available
showvlan
Available
Available
showvnics
Available
Available
smconfigtest
Available
smnodes
Available
smpartition
Available
version
Available
Available
Available
Related Information
