Skip Navigation Links | |
Exit Print View | |
Sun Network QDR InfiniBand Gateway Switch HTML Document Collection for Firmware Version 2.0 |
Network Management Connector and Pins
Preparing to Install the Gateway
Assemble the Ethernet Splitter Data Cables
Install the Gateway in the Rack
Understanding Routing Through the Gateway
Configuring the Fabric Director Node List
Partitioning the InfiniBand Fabric
Administering Gateway Resources
Installing Gateway Supportive Software (Linux)
Creating VNICs Under Gateway Manual Mode (Linux)
Creating VNICs Under Host Manual Mode (Linux)
Creating Virtual IO Adapters (Oracle Solaris)
Controlling Gateway Ports and Parameters
Understanding Oracle ILOM on the Gateway
Upgrading the Gateway Firmware Through Oracle ILOM (CLI)
Upgrade the Gateway Firmware (Web)
Display Gateway Status LED States (IPMI)
Remove the Gateway From the Rack
Displays the Subnet Manager log.
showsmlog [-h]
This hardware command displays the log entries for the Subnet Manager within the management controller. Tapping the space bar displays the next screen of the log. Pressing the Q key quits. The -h option provides help.
The showsmlog command is available from the /SYS/Switch_Diag, /SYS/Gateway_Mgmt, and /SYS/Fabric_Mgmt Linux shell targets of the Oracle ILOM CLI interface.
This example shows how to display the Subnet Manager log with the showsmlog command.
Note - The output of the example is a very small portion and will differ from your output.
# showsmlog Aug 13 15:58:22 679655 [B75F1B90] 0x01 -> __osm_mcmr_rcv_join_mgrp: ERR 1B11: method = Subn AdmSet, scope_state = 0x1, component mask = 0x0000000000010003, expected comp mask = 0x0000 0000000130c7, MGID: ff12:e01b:2::22:2000 from port 0x0003ba000100e371 (mnm34-60 HCA-1) Aug 13 15:58:22 692653 [B75F1B90] 0x01 -> __osm_mcmr_rcv_join_mgrp: ERR 1B11: method = Subn AdmSet, scope_state = 0x1, component mask = 0x0000000000010003, expected comp mask = 0x0000 0000000130c7, MGID: ff12:e01b:3::22:b000 from port 0x00212800013ece9f (mnm34-55 HCA-1) . . .
