Skip Navigation Links | |
Exit Print View | |
Sun Network QDR InfiniBand Gateway Switch HTML Document Collection for Firmware Version 2.0 |
Network Management Connector and Pins
Preparing to Install the Gateway
Assemble the Ethernet Splitter Data Cables
Install the Gateway in the Rack
Understanding Routing Through the Gateway
Configuring the Fabric Director Node List
Partitioning the InfiniBand Fabric
Administering Gateway Resources
Installing Gateway Supportive Software (Linux)
Creating VNICs Under Gateway Manual Mode (Linux)
Creating VNICs Under Host Manual Mode (Linux)
Creating Virtual IO Adapters (Oracle Solaris)
Controlling Gateway Ports and Parameters
Understanding Oracle ILOM on the Gateway
Upgrading the Gateway Firmware Through Oracle ILOM (CLI)
Upgrade the Gateway Firmware (Web)
Display Gateway Status LED States (IPMI)
Remove the Gateway From the Rack
Compares topology file to InfiniBand fabric.
matchtopology [-s systemname] topofile|[-h]
where:
systemname is the local system name in the topology file, should it be other than the host name.
topofile is the filename and path to the topology file used for matching.
This hardware command compares the topology file created with the generatetopology command with the current InfiniBand fabric topology. An error is displayed upon mismatch.
The matchtopology command is available from the /SYS/Fabric_Mgmt Linux shell target of the Oracle ILOM CLI interface.
This table describes the options to the kommand command and their purposes.
This example shows how to compare the topology file to the current topology with the matchtopology command.
# matchtopology AUG22.topo Topology matching will take some time. Please wait! -I--------------------------------------------------- -I- Topology matching results -I--------------------------------------------------- -I- The topology defined in topo1.topo perfectly matches the discoverd fabric. ---------------------------------------------------------------- #
