Skip Navigation Links | |
Exit Print View | |
Sun Network QDR InfiniBand Gateway Switch HTML Document Collection for Firmware Version 2.0 |
Network Management Connector and Pins
Preparing to Install the Gateway
Assemble the Ethernet Splitter Data Cables
Install the Gateway in the Rack
Understanding Routing Through the Gateway
Configuring the Fabric Director Node List
Partitioning the InfiniBand Fabric
Administering Gateway Resources
Installing Gateway Supportive Software (Linux)
Creating VNICs Under Gateway Manual Mode (Linux)
Creating VNICs Under Host Manual Mode (Linux)
Creating Virtual IO Adapters (Oracle Solaris)
Controlling Gateway Ports and Parameters
Understanding Oracle ILOM on the Gateway
Upgrading the Gateway Firmware Through Oracle ILOM (CLI)
Upgrade the Gateway Firmware (Web)
Display Gateway Status LED States (IPMI)
Inspect the Data Cable Hardware
Inspect the Data Cable Connectors or Transceivers
Remove the Gateway From the Rack
Before You Begin
Note - These instructions are valid for both InfiniBand data cables and pre-assembled Ethernet splitter data cables. See Gateway Installation, assembling the Ethernet splitter data cables, for instructions how to assemble Ethernet splitter data cables.
Ensure that the L groove is up for the top row of receptacles, or that the L groove is down for the bottom row of receptacles.
Note - On some QSFP cable connectors, there is a retraction strap. Both the retraction strap and L groove indicate the reference surface for the connector. When installing QSFP cables in the top row receptacles (0A, 1A, 2A, and so on), ensure that the L groove and retraction strap are up. When installing QSFP cables in the bottom row receptacles (0B, 1B, 2B, and so on) ensure that the L groove and retraction strap are down. See Identify the Data Cable.
As you slide the connector in, the shell should be in the center of the QSFP receptacle.
Close hook-and-loop fasteners at bundles and securing hard points.
