Skip Navigation Links | |
Exit Print View | |
Sun Network QDR InfiniBand Gateway Switch HTML Document Collection for Firmware Version 2.0 |
Network Management Connector and Pins
Preparing to Install the Gateway
Assemble the Ethernet Splitter Data Cables
Install the Gateway in the Rack
Understanding Routing Through the Gateway
Configuring the Fabric Director Node List
Partitioning the InfiniBand Fabric
Administering Gateway Resources
Installing Gateway Supportive Software (Linux)
Creating VNICs Under Gateway Manual Mode (Linux)
Creating VNICs Under Host Manual Mode (Linux)
Creating Virtual IO Adapters (Oracle Solaris)
Controlling Gateway Ports and Parameters
Understanding Oracle ILOM on the Gateway
Upgrading the Gateway Firmware Through Oracle ILOM (CLI)
Upgrade the Gateway Firmware (Web)
Display Gateway Status LED States (IPMI)
Remove the Gateway From the Rack
Displays gateway port status.
showgwports [-v][-h]
This hardware command displays information about the gateway Ethernet ports. The information includes:
GUIDs
Node descriptions and names
Ports
LIDs
States
Modes
Speed
MTU
This table describes each of the columns of the output
The showgwports command is available from the /SYS/Gateway_Mgmt and /SYS/Fabric_Mgmt Linux shell targets of the Oracle ILOM CLI interface.
This table describes the options to the showgwports command and their purposes.
This example shows how to display verbose information about the gateway Ethernet ports using the showgwports command.
Note - Your output will differ from that of the example.
# showgwports -v BRIDGE DEVICES: --------------- NodeGUID NodeDescrition --------------------------------- 0x0021283bad45c000 SUN IB QDR GW switch gw-2 Bridge 0 0x0021283bad45c040 SUN IB QDR GW switch gw-2 Bridge 1 INTERNAL PORTS: --------------- Device Port Portname PeerPort PortGUID LID IBState GWState Speed VLs MTU ----------------------------------------------------------------------------------------------- Bridge-0 1 Bridge-0-1 4 0x0021283bad45c001 0x0007 Active Up 40Gbs 2 4096 Bridge-0 2 Bridge-0-2 3 0x0021283bad45c002 0x0008 Active Up 40Gbs 2 4096 Bridge-1 1 Bridge-1-1 2 0x0021283bad45c041 0x0009 Active Up 40Gbs 2 4096 Bridge-1 2 Bridge-1-2 1 0x0021283bad45c042 0x000a Active Up 40Gbs 2 4096 CONNECTOR 0A-ETH: ----------------- Port Bridge Adminstate Link State Linkmode Speed MTU TxPause RxPause ------------------------------------------------------------------------------------------------- 0A-ETH-1 Bridge-0-2 Enabled Up Up XFI 10Gb/s 9600 Global Global 0A-ETH-2 Bridge-0-2 Enabled Up Up XFI 10Gb/s 9600 Global Global 0A-ETH-3 Bridge-0-1 Enabled Up Up XFI 10Gb/s 9600 Global Global 0A-ETH-4 Bridge-0-1 Enabled Up Up XFI 10Gb/s 9600 Global Global CONNECTOR 1A-ETH: ----------------- Port Bridge Adminstate Link State Linkmode Speed MTU TxPause RxPause ------------------------------------------------------------------------------------------------- 1A-ETH-1 Bridge-1-2 Enabled Up Up XFI 10Gb/s 9600 Global Global 1A-ETH-2 Bridge-1-2 Enabled Up Up XFI 10Gb/s 9600 Global Global 1A-ETH-3 Bridge-1-1 Enabled Up Up XFI 10Gb/s 9600 Global Global 1A-ETH-4 Bridge-1-1 Enabled Up Up XFI 10Gb/s 9600 Global Global #
