Skip Navigation Links | |
Exit Print View | |
Sun Network QDR InfiniBand Gateway Switch HTML Document Collection for Firmware Version 2.0 |
Network Management Connector and Pins
Preparing to Install the Gateway
Assemble the Ethernet Splitter Data Cables
Install the Gateway in the Rack
Understanding Routing Through the Gateway
Configuring the Fabric Director Node List
Partitioning the InfiniBand Fabric
Administering Gateway Resources
Installing Gateway Supportive Software (Linux)
Creating VNICs Under Gateway Manual Mode (Linux)
Creating VNICs Under Host Manual Mode (Linux)
Creating Virtual IO Adapters (Oracle Solaris)
Controlling Gateway Ports and Parameters
Understanding Oracle ILOM on the Gateway
Upgrading the Gateway Firmware Through Oracle ILOM (CLI)
Upgrade the Gateway Firmware (Web)
Display Gateway Status LED States (IPMI)
Remove the Gateway From the Rack
Provides help with Oracle ILOM commands.
help [-o terse|verbose][command|legal|targets|target|target property]
where:
command is the Oracle ILOM command for which you are seeking help.
target is the target for which you are seeking help.
property is the property of the target for which you are seeking help.
This Oracle ILOM command gives information and assistance about commands and targets. The -o option enables either terse or verbose output. The help targets command displays a basic list of targets. The help legal command displays the legal notice.
This example shows how to display verbose help about the exit command with the help command.
-> help -o verbose exit The exit command is used to terminate a session. Usage: exit Example: -> exit Connection to nyc-sp closed. ->
Gateway Reference, help command
