Skip Navigation Links
Exit Print View
Sun Network QDR InfiniBand Gateway Switch HTML Document Collection for Firmware Version 2.0
search filter icon
search icon
Document Information
Using This Documentation
Product Notes
Related Documentation
Feedback
Support and Accessibility
Installation
Understanding the Gateway
Gateway Overview
Physical Specifications
Environmental Requirements
Acoustic Noise Emissions
Electrical Specifications
Network Management Connector and Pins
Data QSFP Connector and Pins
Understanding Cabling
Routing Service Cables
Understanding Data Cabling
Preparing to Install the Gateway
Installation Preparation
Installation Responsibilities
Installation Sequence
Assemble the Ethernet Splitter Data Cables
Route the Data Cables
Installing the Gateway
Install the Gateway in the Rack
Powering On the Gateway
Connecting Data cables
Administration
Troubleshooting the Gateway
Gateway Hardware Problems
InfiniBand Fabric Problems
Identifying LEDs
Understanding Routing Through the Gateway
Switch GUIDs Overview
Configuration Overview
Hardware Command Overview
InfiniBand Command Overview
ILOM Command Overview
Administering the Chassis
Monitoring the Chassis
Controlling the Chassis
Monitoring the I4 Switch Chip
Monitoring the Subnet Manager
Configuring the Fabric Director Node List
Partitioning the InfiniBand Fabric
Administering Gateway Resources
Installing Gateway Supportive Software (Linux)
Creating VNICs Under Gateway Manual Mode (Linux)
Creating VNICs Under Host Manual Mode (Linux)
Creating Virtual IO Adapters (Oracle Solaris)
Monitoring Gateway Resources
Controlling LAGs
Controlling VLANs and VNICs
Controlling Gateway Ports and Parameters
Remote Management
Understanding Oracle ILOM on the Gateway
Oracle ILOM Overview
Supported Features
CLI Overview
Upgrading the Gateway Firmware Through Oracle ILOM (CLI)
Web Interface Overview
Upgrade the Gateway Firmware (Web)
Using the Fabric Monitor
Access the Fabric Monitor
Fabric Monitor Features
Control Panel Function
SNMP Overview
Understanding SNMP Commands
Administering Hardware (IPMI)
ipmitool Overview
Display Gateway Status LED States (IPMI)
Enable the Locator LED (IPMI)
cd Command
create Command
delete Command
dump Command
exit Command (ILOM)
help Command (ILOM)
load Command
reset Command
set Command
show Command
version Command (ILOM)
Service
Replaceable Components
Suggested Tools for Service
Servicing Power Supplies
Inspecting a Power Supply
Power Off a Power Supply
Remove a Power Supply
Install a Power Supply
Power On a Power Supply
Servicing Fans
Inspecting a Fan
Remove a Fan
Install a Fan
Servicing Data Cables
Inspecting the Data Cables
Remove a Data Cable
Install a Data Cable
Servicing the Battery
Remove the Gateway From the Rack
Replace the Battery
Reference
addlagport Command
allowhostconfig Command
checkboot Command
checkpower Command
checktopomax Command
checkvoltages Command
connector Command
createlag Command
createvlan Command
createvnic Command
dcsport Command
deletelag Command
deletevlan Command
deletevnic Command
dellagport Command
disablecablelog Command
disablegwport Command
disablelagmode Command
disablelinklog Command
disablesm Command
disableswitchport Command
disablevnic Command
disallowhostconfig Command
enablecablelog Command
enablegwport Command
enablelagmode Command
enablelinklog Command
enablesm Command
enableswitchport Command
enablevnic Command
env_test Command
exit Command (Hardware)
fdconfig Command
fwverify Command
generatetopology Command
getfanspeed Command
getmaster Command
getportcounters Command
getportstatus Command
help Command (Hardware)
listlinkup Command
matchtopology Command
setcontrolledhandover Command
setdefaultgwdiscpkey Command
setgwethport Command
setgwinstance Command
setgwsl Command
setgwsystemname Command
setmsmlocationmonitor Command
setsmmkey Command
setsmpriority Command
setsubnetprefix Command
showfruinfo Command
showgwconfig Command
showgwports Command
showlag Command
showpsufru Command
showsmlog Command
showtemps Command
showtopology Command
showunhealthy Command
showvlan Command
showvnics Command
smconfigtest Command
smnodes Command
smpartition Command
version Command (Hardware)
ibdiagnet Command
ibhosts Command
ibnetdiscover Command
ibnetstatus Command
ibnodes Command
ibportstate Command
ibroute Command
ibrouters Command
ibstat Command
ibswitches Command
ibtracert Command
perfquery Command
saquery Command
smpquery Command
Understanding SNMP MIB OIDs
OID Tables Overview
Understanding the ENTITY-MIB MIB OIDs
Index
showvnics Command
Displays VNIC information.
Syntax
showvnics
Description
This hardware command displays VNICs and their parameters. The list of VNICs is in ascending order, with priority in this sequence:
This table describes each of the columns of the output
Column Heading
Description
ID
VNIC ID number. Roughly indicates creation sequence.
STATE
Logical state of the VNIC. Can be:
  • Up
  • Down
  • Active
  • Disabled
FLG
  • H – VNIC created by Host Manual Mode.
  • N – VNIC created by Gateway Manual Mode.
  • A – VNIC created by Gateway Automatic Mode.
IOA_GUID
The IO adapter’s GUID, presented as eight colon-delimited hexadecimal pairs. Not to be confused with a MAC address.
NODE
Node description. Might also be a fully qualified hostname.
IID
Identifier assigned to the VNIC by the host. Not to be confused for the ID (VNIC ID).
MAC
VNIC MAC address.
VLN
VLAN identifier. A VLAN identifier of 0, -1, or NO indicates that there is no VLAN assigned.
PKEY
Partition key.
GW
Gateway connector. 0A-ETH-1 to 0A-ETH-4 and 1A-ETH-1 to 1A-ETH-4.
The showvnics command is available from the /SYS/Gateway_Mgmt and /SYS/Fabric_Mgmt Linux shell targets of the Oracle ILOM CLI interface.
Example
This example shows how to display the state of the VNICs with the showvnic command.
Note - Your output will differ from that in the example.
# showvnics
ID  STATE     FLG IOA_GUID                NODE       IID  MAC               VLN PKEY   GW
 9 UP          N 00:03:BA:00:01:00:E3:71 mnm34-60 0000 02:02:02:02:02:07 NO  9002   0A-ETH-1
 8 UP          N 00:03:BA:00:01:00:E3:72 mnm34-60 0000 02:02:02:02:02:06 NO  9002   0A-ETH-1
 4 UP          N 00:03:BA:00:01:00:E3:71 mnm34-60 0000 02:02:02:02:02:03 NO  ffff   0A-ETH-2
 5 UP          N 00:03:BA:00:01:00:E3:71 mnm34-60 0002 02:02:02:02:02:04 NO  ffff   0A-ETH-2
 3 DISABLED    N 00:03:BA:00:01:00:E3:71 mnm34-60 0000 02:02:02:02:02:02 NO  ffff   0A-ETH-2
 6 UP          N 00:03:BA:00:01:00:E3:72 mnm34-60 0000 02:02:02:02:02:05 NO  ffff   0A-ETH-2
 7 UP          N 00:03:BA:00:01:00:E3:71 mnm34-60 0000 02:02:02:02:02:01 NO  ffff   0A-ETH-3
Related Information
