Skip Navigation Links | |
Exit Print View | |
Sun Network QDR InfiniBand Gateway Switch HTML Document Collection for Firmware Version 2.0 |
Network Management Connector and Pins
Preparing to Install the Gateway
Assemble the Ethernet Splitter Data Cables
Install the Gateway in the Rack
Understanding Routing Through the Gateway
Configuring the Fabric Director Node List
Partitioning the InfiniBand Fabric
Administering Gateway Resources
Installing Gateway Supportive Software (Linux)
Creating VNICs Under Gateway Manual Mode (Linux)
Creating VNICs Under Host Manual Mode (Linux)
Creating Virtual IO Adapters (Oracle Solaris)
Controlling Gateway Ports and Parameters
Understanding Oracle ILOM on the Gateway
Upgrading the Gateway Firmware Through Oracle ILOM (CLI)
Upgrade the Gateway Firmware (Web)
Display Gateway Status LED States (IPMI)
Remove the Gateway From the Rack
Displays power supply FRU ID information.
showpsufru slot
where slot is the power supply slot (0 or 1).
This hardware command displays FRU ID information for the power supplies.
The showpsufru command is available from the /SYS/Switch_Diag, /SYS/Gateway_Mgmt, and /SYS/Fabric_Mgmt Linux shell targets of the Oracle ILOM CLI interface.
This example shows how to display the FRU ID information for power supply 0 with the showpsufru command.
# showpsufru 0 Sun_SpecPartNo : 885-1165-02 UNIX_Timestamp32 : Sun Jan 3 15:35:39 2010 Sun_Part_Number : 3002143 Sun_Serial_No : BF15WA Vendor_ID_Code : 02a2 Initial_HW_Dash_Level : 02 PSU_Voltage 1 : 0x04b0 (1200) PSU_Current 1 : 0x186a (6250) PSU_Voltage 2 : 0x014a (330) PSU_Current 2 : 0x012c (300) Sun_Hazard_Class_Code : Y IPMI_Board_Manufacturer : EMERSON IPMI_Board_Product_Name : A237 IPMI_Board_Serial_Number: 1357ZHO-0952BF15WA IPMI_Board_Part_Number : 300-2143-02 #
