Skip Navigation Links | |
Exit Print View | |
Sun Network QDR InfiniBand Gateway Switch HTML Document Collection for Firmware Version 2.0 |
Network Management Connector and Pins
Preparing to Install the Gateway
Assemble the Ethernet Splitter Data Cables
Install the Gateway in the Rack
Understanding Routing Through the Gateway
Configuring the Fabric Director Node List
Partitioning the InfiniBand Fabric
Administering Gateway Resources
Installing Gateway Supportive Software (Linux)
Creating VNICs Under Gateway Manual Mode (Linux)
Creating VNICs Under Host Manual Mode (Linux)
Creating Virtual IO Adapters (Oracle Solaris)
Controlling Gateway Ports and Parameters
Understanding Oracle ILOM on the Gateway
Upgrading the Gateway Firmware Through Oracle ILOM (CLI)
Display the Gateway Status LEDs States (Web)
Display the Aggregate Sensors State (Web)
Display Power Supply Status (Web)
Display Board-Level Voltages (Web)
Display Internal Temperatures (Web)
Display the Oracle ILOM Sessions (Web)
Display the Oracle ILOM Event Log (Web)
Checking the Status of Services (Web)
Display the HTTP Service Status (Web)
Display the HTTPS Service Status (Web)
Display the SSL Certificates (Web)
Display the SNMP Service Status (Web)
Display the SNMP Service User Accounts (Web)
Display the SNMP Service Communities (Web)
Display the IPMI Service Status (Web)
Display the DNS Client Status (Web)
Display the SMTP Client Status (Web)
Display the Network Time Protocol Servers (Web)
Verifying Other Aspects With Oracle ILOM (Web)
Display the Alert Properties (Web)
Display the Oracle ILOM User Accounts (Web)
Display the Remote Log Hosts (Web)
Display the Network Management Configuration (Web)
Display the CLI Session Timeout (Web)
Display System Component FRU ID (Web)
Display the Firmware Version (Web)
Display the Oracle ILOM Version (Web)
Display System Identification Properties (Web)
Performing General Tasks on Oracle ILOM Targets (Web)
Restart the Management Controller (Web)
Clear the Oracle ILOM Event Log (Web)
Set the Remote Log Hosts (Web)
Configure the DNS Client (Web)
Configure the SMTP Client (Web)
Back Up the Configuration (Web)
Restore the Configuration (Web)
Create a Snapshot of the Gateway State (Web)
Snapshot Dataset Information (Web)
Set the Network Management Parameters (Web)
Set the System Identification Properties (Web)
Performing Oracle ILOM User Tasks (Web)
Add an Oracle ILOM User Account (Web)
Change an Oracle ILOM User’s Password and or Role (Web)
Delete an Oracle ILOM User Account (Web)
Disable the HTTP Service (Web)
Enable the HTTPS Service (Web)
Install a Custom SSL Certificate (Web)
Remove the Custom SSL Certificate (Web)
Disable the HTTPS Service (Web)
Configure the SNMP Service (Web)
Add SNMP Service User Accounts (Web)
Modify SNMP Service User Accounts (Web)
Delete SNMP Service User Accounts (Web)
Add SNMP Service Communities (Web)
Modify SNMP Service Communities (Web)
Delete SNMP Service Communities (Web)
Download SNMP Service MIBs (Web)
Disable the SNMP Service (Web)
Disable the IPMI Service (Web)
Managing Other Aspects With Oracle ILOM (Web)
Enable Alerts to Send SNMP Traps (Web)
Enable Alerts to Send Email Alerts (Web)
Set the CLI Session Timeout (Web)
Upgrade the Gateway Firmware (Web)
Display Gateway Status LED States (IPMI)
Remove the Gateway From the Rack
The Alert Settings window opens.
A new window opens.
The alert is enabled.
