Skip Navigation Links | |
Exit Print View | |
Sun Datacenter InfiniBand Switch 36 HTML Document Collection for Firmware Version 2.1 |
InfiniBand QSFP Connector and Pins
Understanding InfiniBand Cabling
Preparing to Install the Switch
Assemble the Optical Fiber InfiniBand Cables
Install the Switch in the Rack
Network Management Troubleshooting Guidelines
Understanding Routing Through the Switch
Configuring Secure Fabric Management
Understanding Oracle ILOM on the Switch
Upgrading the Switch Firmware Through Oracle ILOM (CLI)
Upgrade the Switch Firmware (Web)
Display Switch Status LED States (IPMI)
Identify Faults in the Oracle ILOM Event Log
Determining the Alarm State of a Component or System
Determine If a Power Supply Is Faulty
Inspecting the InfiniBand Cables
Determine If the Battery Is Faulty
Remove the Switch From the Rack
Creates a target or property.
create target [property = value property = value ...]
where:
target is the target and path to create or act upon.
property is the property of the target to create.
value is the value of the property created.
This Oracle ILOM command creates the specified target with the specified properties. Your user must have administrator (a) privileges to use this command.
This example shows how to create a /SP/users/test user target with the create command.
-> create /SP/users/test Creating user... Enter new password: password Enter new password again: password Created /SP/users/test ->
