Skip Navigation Links | |
Exit Print View | |
Sun Datacenter InfiniBand Switch 36 HTML Document Collection for Firmware Version 2.1 |
InfiniBand QSFP Connector and Pins
Understanding InfiniBand Cabling
Preparing to Install the Switch
Assemble the Optical Fiber InfiniBand Cables
Install the Switch in the Rack
Network Management Troubleshooting Guidelines
Understanding Routing Through the Switch
Configuring Secure Fabric Management
Understanding Oracle ILOM on the Switch
Upgrading the Switch Firmware Through Oracle ILOM (CLI)
Upgrade the Switch Firmware (Web)
Display Switch Status LED States (IPMI)
Identify Faults in the Oracle ILOM Event Log
Determining the Alarm State of a Component or System
Determine If a Power Supply Is Faulty
Inspecting the InfiniBand Cables
Determine If the Battery Is Faulty
Remove the Switch From the Rack
Displays primary (or Master) Subnet Manager node information.
getmaster [-l]
This hardware command returns information about the node that hosts the primary (or master) Subnet Manager of the InfiniBand fabric. The -l option provides a short historical list of Subnet Manager activity.
The getmaster command is available from the /SYS/Switch_Diag and /SYS/Fabric_Mgmt Linux shell targets of the Oracle ILOM CLI interface.
This example shows how to display information about the node that hosts the master Subnet Manager with the getmaster command.
FabMan@switch_name->getmaster -l Local SM enabled and running, state MASTER SM monitoring history: 20120829 03:55:52 Master SubnetManager on sm lid 1 sm guid 0x21283a8980a0a0 : SUN DCS 36P QDR mnm 10.132.124.33 20120829 04:20:17 whereismaster stopped 20120829 04:21:23 whereismaster started 20120829 04:21:25 No Master SubnetManager seen in the system 20120829 04:21:35 Master SubnetManager on sm lid 1 sm guid 0x21283a8980a0a0 : SUN DCS 36P QDR mnm 10.132.124.33 . . . FabMan@switch_name->
